Winfield -- Snubber circuit design -- max voltage (TIG welder)
I
Ignoramus17256
Ignoramus26745 wrote...
I do fault your posts, because usually it's not clear exactly what
configuration you are considering. That's because we must attempt
to make "schematic" drawings from your incomplete or slightly vague
verbal descriptions, which is not satisfactory. I suggest that you
learn to make simple ASCII drawings and start illustrating your posts.
You can also learn how to simplify your circuit and thereby show only
the relevant parts in your post. Then we can give you accurate and
useful analysis and advice. And we'll all be happy.
I made a little page explaining where the inverter will be placed,
with links to PDF schematic of the welder and pictures of it.
http://igor.chudov.com/projects/Homemade-TIG-DC-to-AC-Inverter/Schematic/Placement/
Your comment on my original question (how to properly select snubber
characteristics) would be appreciated.
i
