Wireless Digital Transmitter/Receiver for connecting two FPGA boards.
Patrick Twomey
I am trying to connect two FPGA development boards together and am
wondering does anyone know of any products that might suit. The boards in
question are two Celoxica RC100 development boards. Video in is from an
analog camera. The video data is converted to digital and stored on
SRAM. There is an expansion header for inter-connectivity. On the other
board video out to a monitor occurs after reading data from the SRAM on
this board. Have connected to two boards via a ribbon cable connected to
the expansion headers. Want to replace this cable with wireless or
optical transmission. Is there any development boards available for
this. The pixel clock is 10 MHz and there are at least 16 bits per pixel
(32 aftere error correction encoding). Access to a 80 MHz on board clock
is available. Any help would be much appreciated.
CWatters
Tricky. You appear to need a 320Mbit/sec data rate.
It would be easier to put the wireless link between the camera and the
Celoxica board.
You can get cheap Video Senders that operate on the 2.4GHz band but they
will probably cause problems for any 802.11b wireless LANs you may have.
Patrick Twomey
The fact I need a 320 Mbps data rate is a major problem. I can't find
anything that suits. Unfortunately I can't use a wireless camera as my
project is to test error-correction codes. The system will be camera
-> Fpga-based error-correction Encoder -> Transmitter at one end of
room and
Receiver -> FPGA-based decoder -> Monitor at other end of room.
Only need to transmit over max bout 5 m. Theres no WLAN in area so
won't interfere with them, thats not a problem. An optical or infrared
(IR) system seems best bet. Any ideas of how to set one of these up.
Chang
Hi, if you want to test error correction codes you don't need the
wireless transmission. Connect your boards with coaxial cable.
Additional attenuators may substitute path loss. A noise generator may
be coupled in, too.
CWatters
Yes I agree with that.
It's a lot easier and cheaper to find a calibrated "noise generator" for
coax than it is for a wireless system.
