WMA audio, high-frequency, weak bits
Radium
Where can I find software that lets me play with WMA?
I would like to make a WMA file with the following:
1. 44,100 Hz sample rate or higher
2. Stereo or mono
3. 24 kbps bit-rate or less
Any software that can do this or something close?
N
Norbert Hahn
2. Stereo or mono
You may look at http://www.mediatwins.com/products/1707-4.htm
or try MP3 encoders, not to forget RA.
Norbert
CBM
Dam Windows
Now I need to get XP to use their free program..
Not so free is it.
Radium
It does not allow you to select custom bit-rates or
sample-rates!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I was looking for something that allows me to select a bit-rate of 24
kbps with 44100 Hz!!!!!!!!!!
It should allow a high sample rate with a low bit-rate!!!!!
AND should let the user decide the sample rate and the
bit-rate!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It does NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I HATE YOU MICROSOFT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
YOU SHIT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
rm -rf Linux
Calm down little boy.
"Arny Krueger" <[email protected]> wrote in message
http://www.microsoft.com/windows/windowsmedia/9series/encoder/default.aspx
Charles Tomaras
CBM said:
Dam Windows
Not so free is it.
Well, XP and Win2K have been out for a number of years now. Unless your
computer hardware is older and fairly limited they are much more capable
OS's than 98 or ME.
