Wot is chasis
Y
yuvraj
Hello frnds
What is the exact meaning of Chasis
What is the difference between Chasis and Ground(Common or Return)
Can I refer Chasis as the Body Ground
Expecting your positive and electrally correct reply
Thank
Regards
YUVRA
Service & Development Enginee
Dan Hollands
yuvraj said:
Hello frnds,
What is the exact meaning of Chasis?
What is the difference between Chasis and Ground(Common or Return)?
Can I refer Chasis as the Body Ground?
Expecting your positive and electrally correct reply!
Regards,
YUVRAJ
Service & Development Engineer
Chassis usually means the metal structure that holds the electronic devices.
In the days of vacuum tubes it was the metal plate on which the tube sockets
were mounted. Today it can be any mechanical structure that holds the
components
The chassis is often grounded (earth ground) for safety purposes if it
possible for the user to come in contact with it. It may be used as a zero
volt referance ground for the electronics. Whether the chassis is grounded
and how it used is dependant on the application and the local safety
requirements.
I have never heard of the term "body ground" being used for anything.
Dan
Dan Hollands
1120 S Creek Dr
Webster NY 14580
585-872-2606
[email protected]
www.QuickScoreRace.com
Pooh Bear
components
requirements.
Maybe he was thinking of Frame Ground ( US usage ) aka FG.
Frame ( USA ) = chassis ( UK )
Graham
