Would an audio test CD help trouble shoot a rattling noise in speaker?
eastcoastguyz
(Please be kind, I am not an audio expert.)
I have a TV which makes a rattling noised when certain low frequencies
are played at a normal volume. This happens from either cable or
playing something from a DVD. Before I remove the cover and start to
try tightening screws up and other things, I would like to be able to
duplicate the problem while attemping to fix this problem.
I thought perhaps this could be done with an audio test CD I have
heard about. I was thinking I would play it through the DVD player
connected to the TV, and then when it makes the rattled, know that I
have isolated it to begin to fix this.
I don't know if I would have any other use for a $100 audio test CD
beyond this purpose, so I was wondering if there already exists some
audio test samples that are free I could download someplace that would
do the trick. The rattle doesn't happen often enough to simply leave
the TV on while trying to duplicate the problem. I don't know how low
of a frequency it is, just that it is low when it rattles. This is
just a normal JVC TV, no surround sound or anything additional added
to it. Thanks!
Mr.T
Fairly common for the small cheap speakers used in most TV's to rattle when
any significant bass levels are attempted.
Why not just use one of the DVD's you are already having trouble with?
Turn up the volume, and bass controls if your TV has them. Plug the
subwoofer output from the DVD player into the TV audio inputs if you can,
then play almost any action movie with lots of low frequency rumble.
to it. Thanks!
Can you plug your computer sound output into the TV audio input? Then you
need a sinal generator/oscillator program that you can adjust the frequency
to find the worst resonance frequencies for the TV speaker. But yes you
could also make your own test CD's for nothing using a program like
Audacity. A low frequency sweep signal is usually helpful.
Frankly I find simply tightening the speakers and packing any plastic
surrounds with rubber to stop vibration helps, unless you want to really fix
the problem by using much better external speakers. That always works for
me.
MrT.
H
Homer J Simpson
OK.
heard about.
No point - wouldn't help. The usual way is to feed 3 VAC into the audio
system and look for the rattle. Failing that, you need an audio generator to
drive the system.
Trevor Wilson
to it. Thanks!
**No need to shell out big Bucks on a test CD. Just burn your own. Here is a
freeware package which should allow you to do just that:
http://www.dr-jordan-design.de/signalgen.htm
Just dial up a low frequency (say 50Hz) and test.
N
N Cook
to it. Thanks!
Its surprising how much distortion can be due to just a paper clip or bit of
machining swarf touching the cone and attracted by the magnet. Try a
different speaker on the same feed is my suggestion.
Mark D. Zacharias
to it. Thanks!
Don't remember what web site but I was able to download a couple drum
samples which greatly aided my troubleshooting once. The piece I was working
on didn't even act up using sine waves, only when lower frequency music was
being played.
Maybe Google "download drum sample" and see what you find.
Mark Z.
Dave Plowman (News)
working on didn't even act up using sine waves, only when lower
frequency music was being played.
The best check is a warbling sweep. Check out the one I suggested earlier.
That's what speaker makers use.
GregS
Sine waves can detect resonances. I have always used low bandwidth music,(AM radio)
to shake up rattles in the higher registers. All you have to do is turn the switch
and work the knobs, or buttons.
greg
Dave Plowman (News)
music,(AM radio) to shake up rattles in the higher registers. All you
have to do is turn the switch and work the knobs, or buttons.
Trouble is you can't *guarantee* random music will have the correct
frequencies to show up a rattle etc. Hence the idea of using a repeatable
test. The beauty of the 'warble' is going either side of the spot
frequency tends to excite any resonance more readily.
Mr. Land
to it. Thanks!
How old is the TV?
I've seen really old ones where the cement used to adhere the speakers
voice coil wire to the paper cylinder has deteriorated with age such
that some of the windings come loose now float around, scraping
against the other parts of the speaker. This is especially audible at
lower freqs. I'd bet that's what it is.
mark
Mr. Land said:
How old is the TV?
Why not just try another speaker if it's old a lot of times the cone is
torn or the speaker is just bad in some way.
Bennett Price
If the TV has an optional audio input, I'd suggest just plugging in an
audio cable, turning up the volume, and put your thumb on the center
prong of the audio cable. This should generate a loud hum that is
likely to reveal the source of the rattle. (If you don't have a cable,
stick a small screwdriver in the audio input and touch it with your
finger while jiggling it around a bit.)
Jeroni Paul
I had a similar problem, it had that flex thing that surrounds the
speaker cone broken. It was of some aged material that fell off just
blowing air at it. Fixed it with fine paper adhesive.
