W
Watson A.Name - \Watt Sun, the Dark Remover\
- Jan 1, 1970
- 0
The National LF353 datasheet implies that the LF353 will sub for both
the LM1558 and LM358. The LM358 and its quad version, the LM324, are
both capable of having their inputs at ground or the negative rail.
I look at the National schematic of the LF353 and it shows the inputs
are gates of a differential pair of P-channel depletion mode JFETs. If
both inputs were tied to the positive supply, they would be okay, but I
don't know if they could both be grounded. Does anyone have a
datasheeet or reference that can confirm this or not? Thanks.
Yeah, I googled for datasheets and ended up on semiconductors.com AKA
Philips. I ended up in an endless loop of choosing English language,
discretes, documents, etc. over and over again. Sucks. Really sucks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
