Zener diode reverse characteristic curves.
James Meyer
I was told that there are no knees associated with zener diodes if the
characteristic curves were plotted with the "correct" scales on the V-I axis.
Take a look at figure 5 on page 3 for the CZRA series diodes whose datasheets
can be found at http://www.comchiptech.com/spec/CZRA1110_1350.pdf and tell me
what sorts of axis ate needed to reduce the curve to a straight line.
Jim
Jim Thompson
Jim
A French curve ?:) Sent by "couriel" ?:)
...Jim Thompson
George R. Gonzalez
Jim
There are a lot of problems with this datasheet. One sees this a lot
these days. Why when I was a boy, a datasheet was a datasheet.
I still remember the one for then 2N107........ Oh, what? Where am I?
First of all, these are in no way ZENER diodes. The actual zener
phenomenon only happens below 5 volts or so. Anything over that is
just your regular avalanche phenomenon.
Secondly, these don't seem to be specified as (non-zener) REGULATOR diodes.
They seem to conduct somewhere around 120% of rating, so they're
more likely to be snubber diodes, which you might expect to have much
looser and variable curves than a true REGULATOR diode that you plan
to use to generate a REGULATED voltage.
Now back to your question, If I Recall Correctly, a diode's forward
conduction
curve is an exponential one, so if you plot the forward voltage linearly on
the X axis
and plot the LOG of conducted current on the Y axis, you get pretty
straight line.
You can see a bunch of these in one place in the back of Bob Pease's
excellent
book, "Troubleshooting Analog circuits". This exponential curve goes all
the way down,
way down down down below what we usually think of the lower limit of
conduction,
arounf 0.6 volts for silicon diodes.
Now back to your REAL question, about reverse conduction (which is
confusingly
called "forward" or "normal" conduction for Zener (and Zener-workalike)
diodes.
It's probably not far off an exponential curve, with perhaps the x intercept
shifted by
the Zener voltage.
Maybe you could look at some Zener SPICE models and see what they use?
James Meyer
...Jim Thompson
Whenever I see a post that uses any of the words "no, never, all, and
always", I'm almost 99 percent sure that an exception exists somewhere. :cool:
That's why I usually try to include a few "weasle-words" in my posts.
Most of the time. :cool:
Jim
James Meyer
Most of the Google hits I got had to do with SPICE models. I was wary
of quoting them because I had the feeling that they were developed to show the
designer what he felt he *wanted* to see rather than what actually existed.
My response was to a previous message that stated categorically that
there were *NO* knees associated with diodes, not even with the reverse
characteristics of "zener" diodes.
That's clearly a specious statement.
Jim
W
Winfield Hill
George wrote...
(which is confusingly called "forward" or "normal" conduction
for Zener (and Zener-workalike) diodes. It's probably not far
off an exponential curve, with perhaps the x intercept shifted
by the Zener voltage.
Actually, from measurements and studies I have made, the
common "avalanche" zener diodes (all those above say 8V)
are generally VERY far off from any type of exponential
characteristic.
For example at low currents where the zener knee is first
encountered (yes there is a definite knee for most types)
the zener voltage may actually drop as the zener current
is increased. Furthermore, after the conduction current
is well established, the voltage drop at higher currents
can look more like a fixed unvarying zener breakdown in
series with a fixed internal series resistance. This is
clearly seen at least in pulsed high-current testing.
And to further complicate matters, this "fixed" breakdown
voltage has a positive temperature coefficient (which can
be quite large at high zener voltages), so along with the
series resistance this changes the measured voltage as the
current and the dissipated power is increaseed, and adds
time course and package mounting issues to the situation.
Whew, all this talk of breakdown makes me hungry, I'm off
to grab some lunch.
- Win
Jon Elson
Jim
Figure 5 is the voltage drift with respect to temperature.
Figure 4 shows the current vs. reverse voltage, and the knee on this
curve is quite obvious. Do you mean you need a linearized temperature
coefficient, or linearized voltage/current? Although you can't get it in
a 100+ V range, there are some great reference 'diodes', like the LM399,
LM4040, etc. that have much improved characteristics.
Jon
John Larkin
Wake up, George. It's 2003. Nobody proof-reads data sheets any more.
John
Jim Meyer
Here's why I can't take SPICE models and simulations seriously....
In the listing below, change the two lines as indicated, run the
simulation again, and then explain why there is a *negative* 390 mV
potential across D1 at low current levels.
Using LT SwitcherCADIII I got this simulation result. Run the
simulation and select "volts" as the parameter to plot.
Zener X-Y.asc file follows....
Version 4
SHEET 1 880 680
WIRE -176 208 -176 128
WIRE -176 128 16 128
WIRE 48 128 48 208
WIRE -176 272 -176 336
WIRE -176 336 -64 336
WIRE 48 336 48 272
WIRE -64 384 -64 336
WIRE -64 336 48 336
WIRE 16 112 16 128
WIRE 16 128 48 128
FLAG -64 384 0
FLAG 16 112 volts
IOPIN 16 112 Out
SYMBOL zener 64 272 R180
WINDOW 0 24 72 Left 0
WINDOW 3 24 0 Left 0
SYMATTR InstName D1
SYMATTR Value BZX84C6V2L
to
SYMATTR Value 1N750
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL load -160 272 R180
WINDOW 0 48 56 Left 0
WINDOW 3 48 28 Left 0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName I1
SYMATTR Value 0
TEXT -320 80 Left 0 !.dc dec I1 .01e-9 19e-3
to
TEXT -320 80 Left 0 !.dc dec I1 .01e-9 200e-3
Jim Thompson
Version 4
SHEET 1 880 680
WIRE -176 208 -176 128 [snip]
to
Loks like a "knee" to me.
Jim
I don't have time to load your listing right now... I'm scurrying to
finish a job before my chassis fan dies... the monitor pops up every
thirty minutes or so when the speed drops seriously below spec :-(
But my guess... Mikey uses behavioral diode models which are a wee bit
hokey... they're a voltage source/ideal diode gimmick.
...Jim Thompson
Jim Thompson
One zener model looks somewhat believable and the other looks bogus as
hell. Both from the same library. That's why I use SPICE simulations with not
a grain but with a bucket full of salt.
Jim
I think you'll find that the "true-Spice" models are pretty reliable
if you choose IS, RS, BV and IBV judiciously.
Those models which use a DC source plus an ideal diode can do weird
things.
...Jim Thompson
Ben Bradley
The proper terminology about something which there may be more than
significant doubt is "take it with a grain silo of salt." At least
that's they way I like to say it.
Robert Strand
My tests have shown fairly close to exponential behaviour for zeners with
nominal voltages say below 4.7V, above that voltage they are like you describe.
Rob
Robert Strand
This was a reply to Win's post. It doesn't look that way on my browser!
W
Winfield Hill
Robert Strand wrote...
with nominal voltages say below 4.7V, above that voltage they are like
you describe.
If you search the s.e.d. archives on Google using the words zener
oscillation, you should uncover the half-dozen threads exploring
this subject. Several of us spent far too much time on the issue,
but the interesting physics we found makes for interesting reading.
Some of the posts feature my attempts at ascii oscilloscope traces.
- Win
Robert Strand
this subject.
Win, thanks for the tip. I've have read some of those over the years,
probably not all of them though.
Regards
Rob
