how do i make a constant power load in LTspice?
T
tomrei
Jan 1, 1970
Hi there,
this group looks pretty spamed, but i'll try my luck.
does any one knows how to make a constant power load in the LTspice?
i've tried a few things but they all involving using dynamic
variables.
maybe it's the question of how to use dynamic variable in LTspice.
for example, the idea is:
R1 N002 N001 100
I1 N002 0 {current(p,V(n002))}
V1 N001 0 10 Rser=1
..param p=10
..func current(power,voltage) {power/voltage}
..tran 0 1m 0 1u startup
..backanno
..end
but this won't work since i can't just pass V(n002) as a parameter
since it's a dynamic variable.
is there a way i can fix this?
many thanks
Ren
C
Charlie E.
Jan 1, 1970
Hi there,
variables.
R1 N002 N001 100
V1 N001 0 10 Rser=1
.param p=10
.backanno
.end
many thanks
Ren
Ren,
Not exactly sure what you want to do, but it sounds like you want a
resistance that always consumes the same amount of power, no matter
the voltage across it. A little odd, but probably doable.
In PSpice, you would use a Gvalue part, or a GTable part, where you
connect the sense leads to the output leads. You then define the
output (the current through the device) as I(out) = Vsense/Power
Let me know if you have any questions on the actual execution.
Charlie
russwallac
Feb 27, 2010
2
Hi there,
does any one knows how to make a constant power load in the LTspice?Ren
I've come up with a couple of very easy ways to create constant power loads in LTspice. One is a resistor whose resistance is a function of the voltage across it, and the other is a voltage-dependent current source using a piece-wise linear approximation. Both are bounded to prevent convergence problems, and they work very well for most applications.
The newsgroup software is blocking my attempts to post a link because I haven't posted here before, so I'll do a followup with the link in a couple of minutes.
