RavenPhoenix
- Aug 8, 2010
- 3
- Joined
- Aug 8, 2010
- Messages
- 3
Hi All,
This is my coat check and 1st post rolled into one. I have been reading up on a few post on this forum for help with a problem I am faced with regards to my Logitech Z680 speaker/amp unit.
The unit was working fine one day and just all of a sudden stopped powering on. I initially thought it was the fuse but have confirmed with a spare one and a multimeter continuance test that it's not the problem.
There were no signs of failure prior to the unit actually not powering up at all. I have opened it up and confirmed that there is no burnt capacitors, resistors, IC's e.t.c and it appears that all the LM chip amps are still in fine working order.
I have tried to do some troubleshooting with my limited knowledge and I have come down to what I think is the problem causing part.........The TOROIDAL TRANSFORMER. Although, I am not 100% sure as I'm not very certain on how to test it properly to see if there is a short in the windings.
Before I go any further the specs of the toroid are as follows:
The transformer is a Tenpao Model # TOU543005F0
The diagram on the side shows the Primary as 240v brown 0v black and Secondarys with a 26.2v orange, 0v black, 26.2v yellow, and then a 14.5v blue and 0v blue.
I have tried using the multimeter to test the secondary rails with red probe on orange and black probe on the 0v black but don't seem to get a very clear reading.
What i would really like your much appreciated help with is either how to 100% confirm if it is the transformer that needs replacing or method to test the unit so I get a clear more definitive answer.
If possible I would also like some advice on whether the Toroidal's I found at these sites below will be a suitable replacement for my unit. If so then which one would you recommend.
https://secure.vividcluster.crox.ne....asp?ID=MT2114&CATID=19&form=CAT&SUBCATID=539
OR
http://www.tortech.com.au/product/900/
Sorry to make it such a long post but if you still feel like it is not enough details then please let me know and I will try to answer them to the best of my ability.
Thank you kindly in advance for you help and any sort of assistance/advice will be greatly appreciated.
OR
