Hello,
I am using a servo for an electronics project that only requires the servo to be fully rotated CW or CCW, I dont need for it to be in any other position. I've only found one datasheet for a Parallax brand which explains the PWM control. My question is if I apply 0 volts or ground to the control wire will the servo rotate until the end of its range in one direction? And if I apply 6 volts will it rotate until the end of its range in the other direction? Also, the Parallax datasheet specified a range of 180 degrees, do the typical RC servos have a range of 90 degrees (as Wikipedia suggests)?
Thanks for any feedback,
Chuck
Chuck
