akorcovelos
- Jul 30, 2011
- 26
- Joined
- Jul 30, 2011
- Messages
- 26
Hi all, new here. I saw a great "deal" sitting on the side of the road, an older (1994) Vitamaster treadmill for $50. Got it home, plugged it in and it ran for about 10 seconds, until I tried to increase the incline. I ran it to the highest incline setting and it got stuck there, then the belt stopped.
I pulled the top cover and went through the trouble shooting in the manual, seems like the controller is stuck sending an "up" signal to the incline motor. Even at full incline the motor is powered in the up direction, and the "up" light on the power source is always on.
About this same moment the belt stopped moving, well mostly. It will sometimes move a bit, but even at 10mph setting it barely moves at even a walking pace. According to the trouble shooting guide if the "up" light is stuck on I should tap the relay next to the "up" light, if that doesn't work (didn't) then replace the elevation assembly, then the power supply. I'm pretty certain the actual incline motor is good because while I was trouble shooting it would go into a cycle of up/down with the belt not running when it should have been.
I'm thinking its the controller or power supply because the incline motor seems fine, and the belt did run at proper speed for a short time when I first plugged it in.
The other problem is parts are NLA for this unit, Sears can get me the controller for around $200, but the motors and power supply are NLA....
Hoping someone here can help me get this thing running on a budget that makes sense. I have moderate electronics experience mostly with DIY fuel injections systems, so I can certainly handle following directions with a little guidance and patience.
Here is a link to the Sears page that has some PDFs from the manual and a parts list with diagrams: http://www.searspartsdirect.com/part...W/0886/1307600
TIA!
TIA!
