- Joined
- Jan 21, 2010
- Messages
- 25,510
Connect a piece of wire rope shorter than the cable between the tacho and wherever the other end connects. That way, when you drop the tacho the cable doesn't take the load.
The cables are not made to take a load. even with king kong tightening them, the braid will stretch if pulled hard enough. That is probably enough to make the centre conductor disappear.
Do you have pictures showing how this tacho is mounted and used? I am having trouble thinking how dropping a tacho could be considered normal and how you don't consider yourself thankful that only a cable gets damaged.
