EAGLE CAD board through-hole design issue?
rigers
Dec 18, 2011
1
Hello,
I'm designing a PCB on EAGLE CAD but there seems to be a problem. I am making a circular PCB and it has a .750 inch hole in the middle. The problem is that EAGLE only allows drill sizes up to 0.516024 inch. Does anybody know a way to get around this?
OLIVE2222
Oct 2, 2011
690
Hi rigers,
I am not an Eagle CAD user however the think to do is to place a so called "internal cutout" or similar.
still need to find it in the menu's.
Olivier
IRETST
Dec 7, 2011
4
If you are generating CNC & Gerber data then simply edit the drill table & header on the CNC to show tool X = to 0.75" -
OLIVE2222
Oct 2, 2011
690
Hi,
Modifying the production files will certainly work but it's a bad practice.
The next time the PCB is edited you can forget to apply the trick :(
Olivier
IRETST
Dec 7, 2011
4
Hi,
Olivier
Agreed - but it is a solution that can be used if you are tearing your hair out looking for one!
