Audio transmitter
Ibraim
Jan 5, 2012
3
First, i'm new here, so, nice to meet you! =)
Hi, on te internet there are a lot of simple projects of audio transmitters, but only in radio frequency. Do you know any circuit that works at a frequency that can't be captured by a radio? I need to get the signal through an another circuito, made by me.
Thanks! :)
BobK
Jan 5, 2010
7,682
Infrared would be an option, but you have to have line of sight between the transmitter and receiver.
Bob
Ibraim
Jan 5, 2012
3
Thank's bob, yes, it would be a problem. Isn't possible to create a circuit out of the radio frequency?
A radio works between 88 and 108 Mhz, the transmitter has to be small, but the receptor doesn't...
Any idea? =/
Thank you!
BobK
Jan 5, 2010
7,682
Any idea? =/
Thank you!
88 to 108 MHz is the FM band. This is not all radio frequencies. Your initial post sounded like you wanted a means of transmitting audio that did not use ANY radio frequencies.
Of course you can use frequencies outside the FM band. Amateur radio uses various other bands, for instance.
Bob
Ibraim
Jan 5, 2012
3
I'm sorry, you're right! I mean something different of radio stations, and not the entire spectrum!... Do you know any circuit? The frequency is not important if i can't get the signal with a radio. Recalling that the transmitter has to be small.
Thanks a lot!
