I am going to use the 200w bulb.
I have tried the 200 watt bulb before and the oscillations were still there.
Steve Thanks again will let you know in a few days what I have.
The outputs are not in a friendly location, Can I install a resistor on each rail that feed the collectors of the outputs?
I was thinking, which is dangerous, but this unit draws 450watts at full power. I can run the volume up all the way with no signal with no problems in 2 channel mode. I can also run volume up very high in 4 channel mode with a FM signal. I am using a 100 to a 200 watt bulb. The volume will get higher with the 200 watt bulb with no problems. I also have a variac if needed.
That's within spec for an electrolytic capacitor. If you have any reason to be suspicious about it, you could replace it, but I suspect it won't really make any difference to the problem you're having.I did find a 1000MFD 35V cap that tested at 922mfd. It was attached to the power supply feeding the 400hz oscillator and Dolby processing boards.
With the resistors in series with the output transistors, and with caution, and with a hand close to the power switch, yeah.Do you think it would be smart to try unit off of the dim bulb at this point?
Can I use one resistor for two outputs (1 resistor for 2 NPN transistors and 1 resistor for the 2 PNP transistors)?
No smoke this time around. Why aren't the 1/4 watt resistors failing when smoked?
