jackorocko
- Apr 4, 2010
- 1,284
- Joined
- Apr 4, 2010
- Messages
- 1,284
A npn transistor has to have a positive voltage on the base and a negative voltage on the emitter in order to be on. What will happen if the emitter voltage goes up but the base voltage stays the same? This is called negative feedback because it is out of phase with respect to the base. You know that the voltage across a resistor increases when the current increases? That's why that emitter resistor is in that circuit. For thermal protection. A mosfet doesn't need that because they conduct less current when they get hot.
I don't know the math used to determine what size is needed, but a .1 ohm would probably work.
Negative feedback is also used in high gain circuits that tend to oscillate when you don't want them to.
Yes, that makes perfect sense and .1 Ohm resistor wouldn't effect the rest of the circuit that much. Thanks for the explaining that, learned something new today.
