Wiring power switch on PN64
cosmocdancer77
Jul 13, 2012
5
Hey everyone, just joined the forum:) Hoping to get a little bit of assistance where I have confusion in wiring. The project I am working on is portabalizing a Nintendo 64. I've done a good deal of it already, dismantled, wired step down regulator, wired screen and batteries, etc. I've gotten to a part where I'm a bit unsure of what to do. It is wiring the power switch. I got it from Radio Shack and I know it's the kind that other people have used in the same type of project. I'll attach photos to show which switch and the diagram I am going by. It is a slider switch with 3 levels, meaning there are a total of six pins. One on each side for each position of the switch. I'm wondering, for each connection do I need to wire to all six pins of the switch or just three? Thanks a bunch.
Harald Kapp
14,273
For the schematic you've shown us you need to connect only three pins, but you have to use the pins on the same side (either th eleft three pins or the right three pins). The left and right sets of pins are independent. You can easily verify this with a multimeter.
Harald
cosmocdancer77
Jul 13, 2012
5
Cool, thanks a lot Harold. :) Yeah, I need to learn how to use my multimeter more efficiently. I know how to check for continuity lol.
davenn
14,470
NOTE its's only a 2 position switch, not 3 taking your right hand pic of the switch...
either the centre and top contacts are connected OR the centre and bottom contacts are connected
Dave
cosmocdancer77
Jul 13, 2012
5
Oh, so with the switch I have I couldn't switch it from the wall power, to off, to batteries? Is that what you mean? Thanks
Harald Kapp
14,273
That is not what Dave wrote. Of course you can. The switch has two contact groups with three pins for each group. Within each contact group the center pin is the common pin and is either connected to the pin to left of it or to the pin to the right of it. This makes two switch positions: left and right. Just take the switch in your hands and check it.
Harald
cosmocdancer77
Jul 13, 2012
5
Wait, maybe I am ewrong in my labeling? It is an AC power supply for a Playstation 1. I'm feeding that into the charge jack and the charge jack to the switch. Is that bad? It turns on fine. Thanks
