danny davis
- May 9, 2012
- 306
- Joined
- May 9, 2012
- Messages
- 306
Hi,
At work today, I had to measure a batterys voltage
We used a 100 ohm resistor, Why is that value 100ohms? and not 10 ohms or 50ohms or etc.
The Battery was a 3.0 volt
I put the 100 ohm resistor in series
The Volt meter was in series
The voltage read 3.0 volts
What did I Test?
If I measure the Batterys in circuit , the tech said that the Resistor would have to be a 10K resistor because the circuit is draw small current
But when I put a 100 ohm resistor in series with the battery, what kind of test is this? the impedance voltage?
Putting a 100ohm resistor in parallel with the 3 volt battery I understand
I'm confused about measuring the battery's voltage/current with a 100ohm resistor in series
Block diagram is:
3v battery---> 100ohm in series----> Volt meter
What kind of BATTERY test is this?
Is this the right resistor value to do a series battery test?
I'm not talking about a parallel battery test, I understand that
I just don't understand a series battery test
What did I Test?
Block diagram is:
