multisim convergence assistant
foTONICS
Sep 30, 2011
332
So I'm trying to build this basic cct to regulate 12VDC, I just wanted to add an ammeter to see how much current I'm drawing but I keep getting this confounded assistant that rarely fixes the problem. I'm pretty sure it's the ammeter that is causing the problem but why, is it just that im using one or is it where I placed it that's causing the problem? **cct attached**
shrtrnd
Jan 15, 2010
3,903
If 'U2' is your ammeter, you're shorting your Voltage Regulator to ground.
duke37
Jan 9, 2011
5,364
I do not know anything about Multisim.
C2 delays the feedback and could put the circuit into oscillation. Try removing it or putting it across R2
