Laptop charger broke. I have another one with a different plug. Will this work?
dimebong
Dec 14, 2012
3
My cheap old hot glue gun shorted out and tripped the breaker so i switched it back on and now i've just noticed my laptop (HP G6 1000) charger isn't charging the laptop; It isn't even detected (they were plugged into the same plug board). I can still hear a sound coming from it when i put it up to my ear.
My question is would my old charger work with this laptop?
The specs for the faulty one are:
Output: 18.5V 3.5A 65W
The specs for the other charger are:
Output: 18.5V 4.9A 90W
The replacement charger i've had my eye on online says
DC Output: 19 V - 4.74 A 90W (Also replaces 18.5v-3.5A 65w)
http://www.trademe.co.nz/computers/laptops/power-adaptors/compaq-/-hp/auction-543324759.htm
Does the amperage matter? I don't know a thing about electronics.
Would this charger work if i changed the cables.
CocaCola
Apr 7, 2012
3,635
They should all work, as long as the amperage of the new one is in excess of the original you are fine... The 0.5V different 'should' not be an issue either as almost all devices will tolerate a small variance in voltage...
Do mind polarity of the plug...
The new unit must be able to supply at least the current tho old one did (any more is OK).
The voltage should be as close as possible. An extra half a volt should be perfectly fine.
Just make sure the polarity of the output is the same (i.e. +ve and -ve the same way around)
dimebong
Dec 14, 2012
3
I was just bringing up the one for sale to show that it is compatible with the laptop even though the voltage and amperage is different.
I have an old charger that is 4.9A, and the same voltage. The old charger is 3.5.
All i have to do is switch the cables if that's possible.
You're saying this will work? That's awesome. Saves me from spending $30
dimebong
Dec 14, 2012
3
Cool. I'll try that. I would have had no computer for a good week once this battery ran out.
remote52
Dec 15, 2012
2
psu
i have repaired many laptops and only one that has to have same psu are dells otherwise wont charge battery
Dell can be a bastard like that
