I cannot troubleshoot this lm386 circuit. I believe I have wired everything accordingly to the schematic and I have posted it as well as the breadboard and its components. Could someone please tell me if I am missing anything?
Thanks a lot? So change the input cap from a disc cap to an electrolytic 1 uf? And another question could I place a 25k ohm pot?
That disc ceramic cap is only 220pF. I doubt that's going to help.
Regards,
Relayer![]()
The capacitor you used is 220pF (p = picofarads) i.e 220 picofarads.Why is this? it calls for a .047 cap, would a 220 cap be better?
but you haven't used 0.047µF, but 0.000220µF.Why is this? it calls for a .047 cap
Why should this be better? Also, as Dave has noted, there are these 2 wires from 1 and 8 that in the schematic go to a potentiometer. Your breadboard doesn't show that potentiometer.
Not necessarily so.Because bigger is better?
Thank you all for your help. I completed it on some ic board. Now the only problem I'm having now is that I get some crackle from the speaker. Could it be from improper soldering or what?
