Send data with one wire protocol?
ArFa
Dec 7, 2010
17
Hi there,
I want to send data through one wire protocol from stm8.
So, stm8 will act as one wire slave device, and send those data to another device through one wire protocol.
Please if you can, tell me how to solve this problem !
I suggest you read the documentation on the protocol. (of course you realise that you need more than one wire)
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Try Googling "implement 1-wire slave" (without the quotes). There's been plenty of discussion.
It should not be too difficult, provided that you can guarantee a fairly low interrupt latency - that is, your interrupt handler needs to get control within a few microseconds of the 1-wire master driving the bus low. If it doesn't, it won't be able to hold the bus low when the master releases it, to transmit a 0-bit. So all the other code running on the device must not lock out interrupts for more than a few microseconds, maximum.
A timer running at 1 MHz or higher with an available free-running count register could help with the timing, or you can just use instruction cycle counting if the micro behaves consistently in this respect.
There's a fair amount of work required to implement the full protocol, but if you understand the master end, implementing a slave end shouldn't be too hard.
I've never done it though. There might be a stumbling block somewhere.
Have a look at the other people who have tried it. If you have any specific questions, ask them here and I may be able to help.
Edit: A small amount of external hardware would probably greatly decrease the load and requirements on the firmware. You can get micros with a PLD or FPGA block built in; these would be ideal.
ArFa
Dec 7, 2010
17
Thanks for your answers...
I've an arduino code for master end, and a code for a slave also in arduino.
I understood it, but the problem is that I'm not able to measure the low bus time from master, so i can't read the command by master.
Do you have any idea for programming stm8s from arduino ?
if you are interested, i could post arduino codes, and my stm8s code.
KrisBlueNZ
Nov 28, 2011
8,393
[...] the problem is that I'm not able to measure the low bus time from master, so i can't read the command by master.
It's interesting that you say you can't measure the bus low time on the slave. On the master, you need to be able to distinguish a received 0-bit from a received 1-bit, so your code must already be capable of this; as I see it, the major difference between master and slave is that the slave needs to be able to deal with received bus transitions at any time, and respond within a few microseconds, if it's transmitting. So I assume it's this difference between the master and slave code that causes the problem with measuring the bus low time. I would need to see your master and slave code to be able to say whether you can fix this problem with code changes only.
The best (or only) way to handle one-wire communication in any MCU depends very much on the peripherals available in that MCU.
For example, if you can only interrupt on the falling edge of the 1-wire bus, your interrupt handler needs to quickly branch according to the context of the bus and either transmit a 1-bit, receive a 1-bit, transmit a 0-bit, or receive a 0-bit; in the latter two cases, the MCU needs to wait inside the interrupt handler for the duration of a 0-bit, and this will cause significant overhead and latency for other interrupt sources.
If you have a timer with input capture and/or output compare, especially if there is double-buffering or triple-buffering, you may be able to avoid spending any significant time in the interrupt handler. A master implementation I wrote for the MSP430 received data using an input capture, so it didn't have to wait for the end of a 0-bit; the input capture logic would capture the timestamp of the falling edge and the rising edge, so a simple subtraction would give the low-period time, and the distinction between a 1-bit and a 0-bit could be made from that value.
I haven't used the STM8S myself, but a quick look at a data sheet for a small device shows that it has plenty of input capture and output compare capability. This should be able to help reduce the firmware overhead of implementing a 1-wire receiver. The data sheet I found doesn't describe the CAPCOM features in any detail; if you know of a detailed description, please post the URL.
As I mentioned before, the best option is hardware support - a 1-wire interface circuit that can transmit and receive bits or bytes at a time with only very loose requirements for the firmware, both in terms of overhead, and required interrupt latency.
If you are interested, i could post arduino codes, and my stm8s code.
As I said, I'm not familiar with the STM8S architecture, but I do know the AVR architecture. Actually I think I've written a 1-wire bus driver for AVR, but not a slave. But please go ahead and post the code here and I'll see if I can help.
ArFa
Dec 7, 2010
17
thnx for reply KrisBlueNZ,
Actually I don't know about CAPCOM, but my programming logic is based in interrupts, so every bit received from master fires an interrupt, than I would transmit the data bit.
The codes are as follows:
one wire master -> reader (Arduino for avr):
Code:
#include <inttypes.h>
#include "pins_arduino.h"
extern "C" {
//#include "WConstants.h"
#include "Arduino.h"
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
// you can exclude onewire_search by defining that to 0
#ifndef ONEWIRE_SEARCH
#define ONEWIRE_SEARCH 1
#endif
// You can exclude CRC checks altogether by defining this to 0
#ifndef ONEWIRE_CRC
#define ONEWIRE_CRC 1
#endif
// Select the table-lookup method of computing the 8-bit CRC
// by setting this to 1.  The lookup table no longer consumes
// limited RAM, but enlarges total code size by about 250 bytes
#ifndef ONEWIRE_CRC8_TABLE
#define ONEWIRE_CRC8_TABLE 0
#endif
// You can allow 16-bit CRC checks by defining this to 1
// (Note that ONEWIRE_CRC must also be 1.)
#ifndef ONEWIRE_CRC16
#define ONEWIRE_CRC16 0
#endif
#define FALSE 0
#define TRUE  1
class OneWire
  private:
    uint8_t bitmask;
    volatile uint8_t *baseReg;
#if ONEWIRE_SEARCH
    // global search state
    unsigned char ROM_NO[8];
    uint8_t LastDiscrepancy;
    uint8_t LastFamilyDiscrepancy;
    uint8_t LastDeviceFlag;
#endif
  public:
    OneWire( uint8_t pin);
    // Perform a 1-Wire reset cycle. Returns 1 if a device responds
    // with a presence pulse.  Returns 0 if there is no device or the
    // bus is shorted or otherwise held low for more than 250uS
    uint8_t reset(void);
    // Issue a 1-Wire rom select command, you do the reset first.
    void select( uint8_t rom[8]);
    // Issue a 1-Wire rom skip command, to address all on bus.
    void skip(void);
    // Write a byte. If 'power' is one then the wire is held high at
    // the end for parasitically powered devices. You are responsible
    // for eventually depowering it by calling depower() or doing
    // another read or write.
    void write(uint8_t v, uint8_t power = 0);
    // Read a byte.
    uint8_t read(void);
    // Write a bit. The bus is always left powered at the end, see
    // note in write() about that.
    void write_bit(uint8_t v);
    // Read a bit.
    uint8_t read_bit(void);
    // Stop forcing power onto the bus. You only need to do this if
    // you used the 'power' flag to write() or used a write_bit() call
    // and aren't about to do another read or write. You would rather
    // not leave this powered if you don't have to, just in case
    // someone shorts your bus.
    void depower(void);
#if ONEWIRE_SEARCH
    // Clear the search state so that if will start from the beginning again.
    void reset_search();
    // Look for the next device. Returns 1 if a new address has been
    // returned. A zero might mean that the bus is shorted, there are
    // no devices, or you have already retrieved all of them.  It
    // might be a good idea to check the CRC to make sure you didn't
    // get garbage.  The order is deterministic. You will always get
    // the same devices in the same order.
    uint8_t search(uint8_t *newAddr);
#endif
#if ONEWIRE_CRC
    // Compute a Dallas Semiconductor 8 bit CRC, these are used in the
    // ROM and scratchpad registers.
    static uint8_t crc8( uint8_t *addr, uint8_t len);
#if ONEWIRE_CRC16
    // Compute a Dallas Semiconductor 16 bit CRC. Maybe. I don't have
    // any devices that use this so this might be wrong. I just copied
    // it from their sample code.
    static unsigned short crc16(unsigned short *data, unsigned short len);
#endif
#endif
OneWire::OneWire(uint8_t pin)
	bitmask =  digitalPinToBitMask(pin);
	baseReg = portInputRegister(digitalPinToPort(pin));
#if ONEWIRE_SEARCH
	reset_search();
#endif
#define DIRECT_READ(base, mask)		(((*(base)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)	((*(base+1)) &= ~(mask))
#define DIRECT_MODE_OUTPUT(base, mask)	((*(base+1)) |= (mask))
#define DIRECT_WRITE_LOW(base, mask)	((*(base+2)) &= ~(mask))
#define DIRECT_WRITE_HIGH(base, mask)	((*(base+2)) |= (mask))
// Perform the onewire reset function.  We will wait up to 250uS for
// the bus to come high, if it doesn't then it is broken or shorted
// and we return a 0;
// Returns 1 if a device asserted a presence pulse, 0 otherwise.
uint8_t OneWire::reset(void)
	uint8_t mask=bitmask;
	volatile uint8_t *reg asm("r30") = baseReg;
	uint8_t r;
	uint8_t retries = 125;
	cli();
	DIRECT_MODE_INPUT(reg, mask);
	sei();
	// wait until the wire is high... just in case
	do {
		if (--retries == 0) return 0;
		delayMicroseconds(2);
	} while ( !DIRECT_READ(reg, mask));
	cli();
	DIRECT_WRITE_LOW(reg, mask);
	DIRECT_MODE_OUTPUT(reg, mask);	// drive output low
	sei();
	delayMicroseconds(500); // send reset signal
	cli();
	DIRECT_MODE_INPUT(reg, mask);	// allow it to float
	delayMicroseconds(80);
	r = !DIRECT_READ(reg, mask);
	sei();
	delayMicroseconds(420);
        if(r)
          Serial.println("Presence received");
        else
          Serial.println("Presence not received");
	return r;
// Write a bit. Port and bit is used to cut lookup time and provide
// more certain timing.
void OneWire::write_bit(uint8_t v)
	if (v & 1) {
		cli();
		delayMicroseconds(10);
		DIRECT_WRITE_HIGH(reg, mask);	// drive output high
		sei();
		delayMicroseconds(55);
	} else {
		cli();
		delayMicroseconds(65);
		sei();
		delayMicroseconds(5);
// Read a bit. Port and bit is used to cut lookup time and provide
uint8_t OneWire::read_bit(void)
	uint8_t r;
	cli();
	delayMicroseconds(3);
	DIRECT_MODE_INPUT(reg, mask);	// let pin float, pull up will raise
	delayMicroseconds(9);
	r = DIRECT_READ(reg, mask);
	sei();
	delayMicroseconds(53);
	return r;
// Write a byte. The writing code uses the active drivers to raise the
// pin high, if you need power after the write (e.g. DS18S20 in
// parasite power mode) then set 'power' to 1, otherwise the pin will
// go tri-state at the end of the write to avoid heating in a short or
// other mishap.
void OneWire::write(uint8_t v, uint8_t power /* = 0 */) {
    uint8_t bitMask;
    for (bitMask = 0x01; bitMask; bitMask <<= 1) {
	OneWire::write_bit( (bitMask & v)?1:0);
    if ( !power) {
	cli();
	DIRECT_MODE_INPUT(baseReg, bitmask);
	DIRECT_WRITE_LOW(baseReg, bitmask);
	sei();
// Read a byte
uint8_t OneWire::read() {
    uint8_t bitMask;
    uint8_t r = 0;
	if ( OneWire::read_bit()) r |= bitMask;
    return r;
// Do a ROM select
void OneWire::select( uint8_t rom[8])
    int i;
    write(0x55);           // Choose ROM
    for( i = 0; i < 8; i++) write(rom[i]);
// Do a ROM skip
void OneWire::skip()
    write(0xCC);           // Skip ROM
void OneWire::depower()
	cli();
	sei();
#if ONEWIRE_SEARCH
// You need to use this function to start a search again from the beginning.
// You do not need to do it for the first search, though you could.
void OneWire::reset_search()
  // reset the search state
  LastDiscrepancy = 0;
  LastDeviceFlag = FALSE;
  LastFamilyDiscrepancy = 0;
  for(int i = 7; ; i--)
    ROM_NO[i] = 0;
    if ( i == 0) break;
// Perform a search. If this function returns a '1' then it has
// enumerated the next device and you may retrieve the ROM from the
// OneWire::address variable. If there are no devices, no further
// devices, or something horrible happens in the middle of the
// enumeration then a 0 is returned.  If a new device is found then
// its address is copied to newAddr.  Use OneWire::reset_search() to
// start over.
// --- Replaced by the one from the Dallas Semiconductor web site ---
// Perform the 1-Wire Search Algorithm on the 1-Wire bus using the existing
// search state.
// Return TRUE  : device found, ROM number in ROM_NO buffer
//        FALSE : device not found, end of search
uint8_t OneWire::search(uint8_t *newAddr)
   uint8_t id_bit_number;
   uint8_t last_zero, rom_byte_number, search_result;
   uint8_t id_bit, cmp_id_bit;
   unsigned char rom_byte_mask, search_direction;
   // initialize for search
   id_bit_number = 1;
   last_zero = 0;
   rom_byte_number = 0;
   rom_byte_mask = 1;
   search_result = 0;
   // if the last call was not the last one
   if (!LastDeviceFlag)
      // 1-Wire reset
      if (!reset())
         // reset the search
         return FALSE;
      // issue the search command
      write(0xF0);
      // loop to do the search
      do
         // read a bit and its complement
         id_bit = read_bit();
         cmp_id_bit = read_bit();
         // check for no devices on 1-wire
         if ((id_bit == 1) && (cmp_id_bit == 1))
            break;
         else
            // all devices coupled have 0 or 1
            if (id_bit != cmp_id_bit)
               search_direction = id_bit;  // bit write value for search
            else
               // if this discrepancy if before the Last Discrepancy
               // on a previous next then pick the same as last time
               if (id_bit_number < LastDiscrepancy)
                  search_direction = ((ROM_NO[rom_byte_number] & rom_byte_mask) > 0);
               else
                  // if equal to last pick 1, if not then pick 0
                  search_direction = (id_bit_number == LastDiscrepancy);
               // if 0 was picked then record its position in LastZero
               if (search_direction == 0)
                  last_zero = id_bit_number;
                  // check for Last discrepancy in family
                  if (last_zero < 9)
                     LastFamilyDiscrepancy = last_zero;
            // set or clear the bit in the ROM byte rom_byte_number
            // with mask rom_byte_mask
            if (search_direction == 1)
              ROM_NO[rom_byte_number] |= rom_byte_mask;
            else
              ROM_NO[rom_byte_number] &= ~rom_byte_mask;
            // serial number search direction write bit
            write_bit(search_direction);
            // increment the byte counter id_bit_number
            // and shift the mask rom_byte_mask
            id_bit_number++;
            rom_byte_mask <<= 1;
            // if the mask is 0 then go to new SerialNum byte rom_byte_number and reset mask
            if (rom_byte_mask == 0)
                rom_byte_number++;
                rom_byte_mask = 1;
      while(rom_byte_number < 8);  // loop until through all ROM bytes 0-7
      // if the search was successful then
      if (!(id_bit_number < 65))
         // search successful so set LastDiscrepancy,LastDeviceFlag,search_result
         LastDiscrepancy = last_zero;
         // check for last device
         if (LastDiscrepancy == 0)
            LastDeviceFlag = TRUE;
         search_result = TRUE;
   // if no device found then reset counters so next 'search' will be like a first
   if (!search_result || !ROM_NO[0])
      search_result = FALSE;
   for (int i = 0; i < 8; i++) newAddr[i] = ROM_NO[i];
   return search_result;
#endif
#if ONEWIRE_CRC
// The 1-Wire CRC scheme is described in Maxim Application Note 27:
// "Understanding and Using Cyclic Redundancy Checks with Maxim iButton Products"
#if ONEWIRE_CRC8_TABLE
// This table comes from Dallas sample code where it is freely reusable,
// though Copyright (C) 2000 Dallas Semiconductor Corporation
static const uint8_t PROGMEM dscrc_table[] = {
      0, 94,188,226, 97, 63,221,131,194,156,126, 32,163,253, 31, 65,
    157,195, 33,127,252,162, 64, 30, 95,  1,227,189, 62, 96,130,220,
     35,125,159,193, 66, 28,254,160,225,191, 93,  3,128,222, 60, 98,
    190,224,  2, 92,223,129, 99, 61,124, 34,192,158, 29, 67,161,255,
     70, 24,250,164, 39,121,155,197,132,218, 56,102,229,187, 89,  7,
    219,133,103, 57,186,228,  6, 88, 25, 71,165,251,120, 38,196,154,
    101, 59,217,135,  4, 90,184,230,167,249, 27, 69,198,152,122, 36,
    248,166, 68, 26,153,199, 37,123, 58,100,134,216, 91,  5,231,185,
    140,210, 48,110,237,179, 81, 15, 78, 16,242,172, 47,113,147,205,
     17, 79,173,243,112, 46,204,146,211,141,111, 49,178,236, 14, 80,
    175,241, 19, 77,206,144,114, 44,109, 51,209,143, 12, 82,176,238,
     50,108,142,208, 83, 13,239,177,240,174, 76, 18,145,207, 45,115,
    202,148,118, 40,171,245, 23, 73,  8, 86,180,234,105, 55,213,139,
     87,  9,235,181, 54,104,138,212,149,203, 41,119,244,170, 72, 22,
    233,183, 85, 11,136,214, 52,106, 43,117,151,201, 74, 20,246,168,
    116, 42,200,150, 21, 75,169,247,182,232, 10, 84,215,137,107, 53};
// Compute a Dallas Semiconductor 8 bit CRC. These show up in the ROM
// and the registers.  (note: this might better be done without to
// table, it would probably be smaller and certainly fast enough
// compared to all those delayMicrosecond() calls.  But I got
// confused, so I use this table from the examples.)
uint8_t OneWire::crc8( uint8_t *addr, uint8_t len)
	uint8_t crc = 0;
	while (len--) {
		crc = pgm_read_byte(dscrc_table + (crc ^ *addr++));
	return crc;
#else
// Compute a Dallas Semiconductor 8 bit CRC directly.
	uint8_t crc = 0;
	while (len--) {
		uint8_t inbyte = *addr++;
		for (uint8_t i = 8; i; i--) {
			uint8_t mix = (crc ^ inbyte) & 0x01;
			crc >>= 1;
			if (mix) crc ^= 0x8C;
			inbyte >>= 1;
	return crc;
#endif
#if ONEWIRE_CRC16
static short oddparity[16] = { 0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0 };
// Compute a Dallas Semiconductor 16 bit CRC. I have never seen one of
// these, but here it is.
unsigned short OneWire::crc16(unsigned short *data, unsigned short len)
    unsigned short i;
    unsigned short crc = 0;
    for ( i = 0; i < len; i++) {
	unsigned short cdata = data[len];
	cdata = (cdata ^ (crc & 0xff)) & 0xff;
	crc >>= 8;
	if (oddparity[cdata & 0xf] ^ oddparity[cdata >> 4]) crc ^= 0xc001;
	cdata <<= 6;
	crc ^= cdata;
	cdata <<= 1;
	crc ^= cdata;
    return crc;
#endif
#endif
OneWire  ds(12);
//LiquidCrystal lcd(7,6,5,4,3,2);
byte addr[8];
String keyStatus="";
void setup(void) {
  Serial.begin(115200);
  //lcd.begin(16,2);
void loop(void) {
  //getKeyCode();
  if ( !ds.search(addr)) {
      ds.reset_search();
      return;
  Serial.println("=================================");
  for(int i=0;i<8;i++)
    Serial.print(addr[i],HEX);
    Serial.print(" ");
  Serial.println("\n=================================");
  keyStatus="ok";
  ds.reset();
one wire slave -> writer (Arduino for avr)
Code:
extern "C" {
#include <avr/io.h>
#ifndef ONEWIRESLAVE_CRC
#define ONEWIRESLAVE_CRC 1
#endif
#ifndef ONEWIRESLAVE_CRC8_TABLE
#define ONEWIRESLAVE_CRC8_TABLE 0
#endif
#define FALSE 0
#define TRUE  1
#define ONEWIRE_NO_ERROR 0
#define ONEWIRE_READ_TIMESLOT_TIMEOUT 1
#define ONEWIRE_WRITE_TIMESLOT_TIMEOUT 2
#define ONEWIRE_WAIT_RESET_TIMEOUT 3
#define ONEWIRE_VERY_LONG_RESET 4
#define ONEWIRE_VERY_SHORT_RESET 5
#define ONEWIRE_PRESENCE_LOW_ON_LINE 6
class OneWireSlave {
  private:
    bool recvAndProcessCmd();
    bool waitTimeSlot();
    uint8_t pin_bitmask;
    char rom[8];
  public:
    OneWireSlave(uint8_t pin);
    void setRom(char rom[8]);
    bool waitForRequest(bool ignore_errors);
    bool waitReset(uint16_t timeout_ms);
    bool waitReset();
    bool presence(uint8_t delta);
    bool presence();
    bool search();
    uint8_t sendData(char buf[], uint8_t data_len);
    uint8_t recvData(char buf[], uint8_t data_len);
    void send(uint8_t v);
    uint8_t recv(void);
    void sendBit(uint8_t v);
    uint8_t recvBit(void);
#if ONEWIRESLAVE_CRC
    static uint8_t crc8(char addr[], uint8_t len);
#endif
    uint8_t errno;
/* тайм слот ожидается 120 микросекунд (стандартная длина тайм-слота 60-120 micrs)
 * при компиляции с флагом -Os в цикле ожидания присутствуют следующие команды:
 * ld, ldi, and, and, or, breq, subi, sbci
 * общая продолжительность цикла составляет 10 тактов.
 * Таблицу соответствия между командами микроконтроллера и количеством тактов
 * можно найти в даташите на микроконтроллер, см. раздел
 * Instruction Set Summary в конце даташита. */
#define TIMESLOT_WAIT_RETRY_COUNT microsecondsToClockCycles(120) / 10L
OneWireSlave::OneWireSlave(uint8_t pin) {
    pin_bitmask = digitalPinToBitMask(pin);
void OneWireSlave::setRom(char rom[8]) {
    for (int i=0; i<7; i++)
        this->rom[i] = rom[i];
    this->rom[7] = crc8(this->rom, 7);
#else
    for (int i=0; i<8; i++)
#endif
bool OneWireSlave::waitForRequest(bool ignore_errors) {
    errno = ONEWIRE_NO_ERROR;
    for (;;) {
        if (!waitReset(0) )
            continue;
        if (!presence() )
            continue;
        if (recvAndProcessCmd() )
            return TRUE;
        else if ((errno == ONEWIRE_NO_ERROR) || ignore_errors)
            continue;
        else
            return FALSE;
bool OneWireSlave::recvAndProcessCmd() {
    char addr[8];
    for (;;) {
      switch (recv() ) {
        case 0xF0: // SEARCH ROM
            search();
            return FALSE;
        case 0x33: // READ ROM
            sendData(rom, 8);
            if (errno != ONEWIRE_NO_ERROR)
                return FALSE;
            break;
        case 0x55: // MATCH ROM
            recvData(addr, 8);
                return FALSE;
                if (rom[i] != addr[i])
                    return FALSE;
            return TRUE;
        case 0xCC: // SKIP ROM
            return TRUE;
        default: // Unknow command
            if (errno == ONEWIRE_NO_ERROR)
                break; // skip if no error
            else
                return FALSE;
bool OneWireSlave::search() {
  uint8_t bitmask;
    uint8_t bit_send, bit_recv;
    for (int i=0; i<8; i++) {
        for (bitmask = 0x01; bitmask; bitmask <<= 1) {
            bit_send = (bitmask & rom[i])?1:0;
            sendBit(bit_send);
            sendBit(!bit_send);
            bit_recv = recvBit();
                return FALSE;
            if (bit_recv != bit_send)
                return FALSE;
    return TRUE;
bool OneWireSlave::waitReset(uint16_t timeout_ms) {
  uint8_t mask = pin_bitmask;
    unsigned long time_stamp;
    cli();
    sei();
    if (timeout_ms != 0) {
        time_stamp = micros() + timeout_ms*1000;
        while (DIRECT_READ(reg, mask)) {
            if (micros() > time_stamp) {
                errno = ONEWIRE_WAIT_RESET_TIMEOUT;
                return FALSE;
    } else
        while (DIRECT_READ(reg, mask)) {};
    time_stamp = micros() + 540;
    while (DIRECT_READ(reg, mask) == 0) {
            errno = ONEWIRE_VERY_LONG_RESET;
            return FALSE;
    if ((time_stamp - micros()) > 70) {
        errno = ONEWIRE_VERY_SHORT_RESET;
        return FALSE;
    delayMicroseconds(30);
    return TRUE;
bool OneWireSlave::waitReset() {
    return waitReset(1000);
bool OneWireSlave::presence(uint8_t delta) {
    cli();
    sei();
    delayMicroseconds(120);
    cli();
    sei();
    delayMicroseconds(300 - delta);
    if ( !DIRECT_READ(reg, mask)) {
        errno = ONEWIRE_PRESENCE_LOW_ON_LINE;
        return FALSE;
    } else
        return TRUE;
bool OneWireSlave::presence() {
    return presence(25);
uint8_t OneWireSlave::sendData(char buf[], uint8_t len) {
    uint8_t bytes_sended = 0;
    for (int i=0; i<len; i++) {
        send(buf[i]);
            break;
        bytes_sended++;
    return bytes_sended;
uint8_t OneWireSlave::recvData(char buf[], uint8_t len) {
    uint8_t bytes_received = 0;
        buf[i] = recv();
            break;
        bytes_received++;
    return bytes_received;
void OneWireSlave::send(uint8_t v) {
    for (uint8_t bitmask = 0x01; bitmask && (errno == ONEWIRE_NO_ERROR); bitmask <<= 1)
        sendBit((bitmask & v)?1:0);
uint8_t OneWireSlave::recv() {
    uint8_t r = 0;
        if (recvBit())
            r |= bitmask;
    return r;
void OneWireSlave::sendBit(uint8_t v) {
    cli();
    if (!waitTimeSlot() ) {
        errno = ONEWIRE_WRITE_TIMESLOT_TIMEOUT;
        sei();
        return;
    if (v & 1)
    else {
        cli();
        sei();
    sei();
    return;
uint8_t OneWireSlave::recvBit(void) {
    uint8_t r;
    cli();
        errno = ONEWIRE_READ_TIMESLOT_TIMEOUT;
        sei();
        return 0;
    sei();
    return r;
bool OneWireSlave::waitTimeSlot() {
    uint16_t retries;
    retries = TIMESLOT_WAIT_RETRY_COUNT;
        if (--retries == 0)
            return FALSE;
    while ( DIRECT_READ(reg, mask))
        if (--retries == 0)
            return FALSE;
    return TRUE;
#if ONEWIRESLAVE_CRC8_TABLE
uint8_t OneWireSlave::crc8(char addr[], uint8_t len)
    uint8_t crc = 0;
    while (len--) {
    return crc;
#else
    uint8_t crc = 0;
    while (len--) {
            crc >>= 1;
            inbyte >>= 1;
    return crc;
#endif
#endif
char romadd[8] = {0x01, 0xAD, 0xDA, 0xCE, 0x0F, 0x00, 0x00, 0x00};
OneWireSlave ds(8);
void setup()
{ ds.setRom(romadd);
void loop()
{ ds.waitForRequest(false); }
my code in stm8s for one wire slave writer:
Code:
#include"stm8s.h"
#include <iostm8S105c6.h>
#include <intrinsics.h>
//  Setup Timer 2 to generate an interrupt every 480 clock ticks (30 uS).
char A[64] = "1010101010101010101010101010101010101010101010101010101010101010"; // serial number to send to one wire
//int i ;
void SetupTimer2(char a) //40 us
    TIM2_PSCR = 0x00;       //  Prescaler = 1.
    if(a == 'r') //
      TIM2_ARRH = 0x04;       //  Wait for 480.
      TIM2_ARRL = 0x38;
    else if(a == 'p')
      TIM2_ARRH = 0x01;       //  High byte of 120.
      TIM2_ARRL = 0x18;
    else if(a == 'b')
      TIM2_ARRH = 0x00;       //  wait for 30us.
      TIM2_ARRL = 0x3c;
    else if(a == 'c')
      TIM2_ARRH = 0x00;       //  wait for 10us.
      TIM2_ARRL = 0x14;
   // TIM2_IER_UIE = 1;       //  Turn on the interrupts.
    TIM2_CR1_CEN = 1;       //  Finally enable the timer.
//  Timer 2 Overflow handler.
#pragma vector = TIM2_OVR_UIF_vector
__interrupt void TIM2_UPD_OVF_IRQHandler(void)
    TIM2_SR1_UIF = 0;              //  Reset the interrupt otherwise it will fire again straight away.
    TIM1_IER_UIE = 0;
int i_count;
char proc_isr;
#pragma vector = 6
__interrupt void EXTI_PORTB_IRQHandler(void) // B interrupt
       PB_CR2 = 0x00; // disable EXTI_PORTB
       if(i_count<1)
       SetupTimer2('r'); // delay_us(510);
       __enable_interrupt();
       __wait_for_interrupt();
       //__disable_interrupt();
       PB_ODR_ODR4 = 0;//low -> presence
       PB_DDR = 0xff;
       SetupTimer2('p');//delay_us(140);
       else
       if(i_count<9) // receive command from master -> 0xF0 search();
       else
       if(i_count<73) // send data bits
         if(A[i_count-8] == 0)
           //send 0 bit
           PB_ODR_ODR4 = 0;//low -> bit
           PB_DDR = 0xff;
           SetupTimer2('b');//delay us = 60 us
           // send 1 bit
           PB_ODR_ODR4 = 1;
           PB_DDR = 0x00;
         else
           // send 1 bit
           PB_DDR = 0x00;
           // send 0 bit
           PB_DDR = 0xff;
           PB_DDR = 0x00;
           SetupTimer2('b');//delay 30us for recv signal, do nothing.
       i_count++;
       if(i_count>73)
         i_count = 0;
       //rim();
    PB_CR2 = 0x00;
//  Main program loop.
void main()
   i_count = 0;
   PB_ODR_ODR4 = 1;
   PB_DDR = 0x00; // porta D pin 4 input
   PB_CR1 = 0xff;         //  PB4 is pull-up input.
   PB_CR2 = 0xff;         //  PB4 is with interrupt
   EXTI_CR1_PBIS = 2;      //  Interrupt on falling edge.
   EXTI_CR2_TLIS = 0;      //  Falling edge only.
    i_count = 0;
    while (1)
       PB_CR2 = 0xff;
Note: stm8s has 16 MHz frequency.
KrisBlueNZ
Nov 28, 2011
8,393
OK, I've had a look at your code but it is not well documented.
I would like to see some general documentation about how it all works, and comments at the start of each function describing what the function does, how it does it, what the parameters and return value means, and anything else that will aid understanding by a programmer who is not already familiar with the general design principles and structure of the driver.
In my opinion, this should be a normal part of any program. If you add this documentation I will be able to help you further.
ArFa
Dec 7, 2010
17
#include"stm8s.h"
void SetupTimer2(char a) // this initialize the timer to count for reset, presence and bit slot time
if(a == 'r') // wait reset time = 510us
TIM2_ARRH = 0x04; // High byte of 510 us.
TIM2_ARRL = 0x38;
else if(a == 'p') // count for 120 us
TIM2_ARRL = 0x18;
else if(a == 'b') // count for bit time = 30us
TIM2_ARRL = 0x3c;
// timer will count to it's value and then will be stopped. This enables to do nothings (NOPs)
TIM1_IER_UIE = 0; // disable interrupt
int i_count; // counts how interrupts are coming
#pragma vector = 6
__interrupt void EXTI_PORTB_IRQHandler(void) // portB interrupt
PB_CR2 = 0x00; // disable EXTI_PORTB interrupt
if(i_count<1) // if is the first interrupt then it's reset signal, so wait for 512us (reset plus recovery time) then drive bus low and wait presence time (120us)
SetupTimer2('r'); // set timer to count up to 510us
__enable_interrupt(); // this will enable timer interrupt
__wait_for_interrupt(); // this will wait for timer interrupt and does nothing.
PB_DDR = 0xff; // set portB output
SetupTimer2('p');//set timer to count up to 120us
else
if(i_count<9) // receive command from master (8bits = 8 interrupts)
else
// if A[i_count-8] == 0 then send bit 0, after that, send its complement (like in arduino writer)
// to send 0 bit, set pinPB4 =0, then set portB output and wait for bit time
// to send 1 bit, set pin PB4 = 1, then set portB input (to pull-up bus) and wait bit time
//send 0 bit
PB_DDR = 0xff;
SetupTimer2('b');//delay us = 30 us
// send 1 bit
PB_ODR_ODR4 = 1;
PB_DDR = 0x00;
SetupTimer2('b');//delay us = 30us
else
// if A[i_count -8] == 1 then send 1 bit and its complement
// to send 1 bit then set portB input (to pull-up) and wait for bit time (30us)
// to send 0 bit, set pin PB4 low, portB output and wait bit time (30us)
// send 1 bit
PB_DDR = 0x00;
// send 0 bit
PB_ODR_ODR4 = 0;
PB_DDR = 0xff;
// after the master received data bits, it will send back that bit, it's irrelevant to us, so we will do nothing while it's coming
PB_DDR = 0x00;
i_count++;
if(i_count>73) // if there are 73 interrupts then reset the sequence
i_count = 0; // set i_count = 0, so when other interrupt will come, it will be the reset signal and we will send the presence and other data.
//rim();
PB_CR2 = 0x00; // this will enable the portB interrupt
void main()
i_count = 0;
PB_ODR_ODR4 = 1; // set pin PB4 low, this will be used as one wire pin
PB_DDR = 0x00; // porta D pin 4 input to catch interrupts
PB_CR2 = 0xff; // PB4 is with interrupt.
i_count = 0;
while (1)
in this link you will find the I/O port configuration summary (table 17. page 101/441)
I'm sorry if I don't explained it well :(
thanks in advance ...
KrisBlueNZ
Nov 28, 2011
8,393
OK I'm having a look at your code.
Your comments are very minimal. This makes it hard for me to figure out what your code is doing, because I don't know what you're trying to achieve.
Comments on individual lines are helpful, but larger blocks of comments before functions and at the start, giving the "bigger picture", are extremely valuable to everyone apart from the person who has just written the module and has all that information in their head.
I think a documentation block at the start, explaining the general principles of operation and how the timer and I/O pins are used, would be a great help to me, and to you, when you come back to this code in ten years and can't remember anything about it.
What device ist the code is written to run on? You should make a note of that in the comments.
Finally, a schematic of the one-wire interface would be helpful.
KrisBlueNZ
Nov 28, 2011
8,393
There are several problems with your code. The major problem is the approach you seem to have taken is not workable.
I need to know the exact details of the peripherals you have to work with, so I need the full part number of the device you want to use, as well as the schematic of the 1-wire interface.
Also, why have you chosen that particular device, and do you have the option of using a different device?
ArFa
Dec 7, 2010
17
Look, in the main function are initialization of IO ports to receive external interrupts, when external interrupt is fired, then it checks if it's first or another interrupt, if it's the first interrupt then it is reset interrupt and it remain low for 480us and goes high for 30us, so the whole reset signal width is 510us, after this delay we should send the presence signal for 120us.
If it's 2nd to 9th (8 interrupts after reset interrupt) it does nothing because those interrupts are the master command 0xF0 (search command), after those interrupts, in every interrupt that is fired we will send one or zero bit, which are one wire ID (ibutton ID).
In arduino it says that we should send the bit itself and it's complement.
The whole bit signal width should be 60us, so half of that is 30us.
To achieve these delays I've used the timer2 several initializations, so if we should wait for 510us, we initialize the timer to count up to (510*2)(hex) (I've no idea why it is so), and so on...
So, when we send a bit to the master, we set the bus low or high (depending the value of bit we want to send), set the timer, and wait until the timer interrupt fires, this guarantees us that we've waited Xus (depending what we want to send, presence or bit signal). When timer interrupt fires, it stops the timer so it wont fire again until we don't initialize it again.
Developing environments is IAR Embedded Workbench .
Device type is stm8s105C6 (will act as one wire slave), gps Teltonika FM1100 or arduino (as one wire master).
i have no option of using a different device, i should use anyhow stm8s105f6 and gps Teltonika FM1100.
Another problem is that, gps Teltonika FM1100 (which works with one wire protocol) doesn't read the arduino slave, do you have any idea why?
Thanks in advance
KrisBlueNZ
Nov 28, 2011
8,393
Do you have a schematic diagram for the one-wire interface in the Arduino slave?
Do you have a schematic diagram for the one-wire interface in the STM8S circuit?
What other functions does the firmware in the STM8S module need to perform?
What internal peripherals are available to the 1-wire slave code? Is either of the timers available?
KrisBlueNZ
Nov 28, 2011
8,393
Thanks for the expanation.
I've had a look at your code, the data sheet for the MCU, and the other information you've provided. In my opinion you are a long way from being ready to write this code.
You do not have a specification of what you want to do with the 1-wire interface - you haven't even described your requirements in any detail. You aren't familiar with the MCU architecture. You don't have a schematic. You are way out of your depth.
I don't say these things to be insulting or to put you down; I'm trying to help. If you want to get this project going, you need to hire someone with embedded systems design and programming experience. There is little point in me trying to help because I can't give you the type or level of help you need.
ArFa
Dec 7, 2010
17
Anyway, thank you very much for your replies ... And I'm sorry if I've troubled you :S
