quantumtangles
- Dec 19, 2012
- 153
- Joined
- Dec 19, 2012
- Messages
- 153
Materials scientists have said adding cooling fans to the battery layers (each being about the size of a laptop - stacked one on top of the other) would help, as the internal 'laptops' cannot 'heat-sink' the same way battery layers near the outside of the unit.
There is also talk of thermal runaway...hitting a critical temperature in electrochemical terms, causing a change of state (to gas) putting pressure on the unit case, breaking seals and leading to thermal runaway.
But these materials science ideas do not make that much sense to me, not least because they are too obvious. Boeing engineers are really first rate. Amongst the very best engineers in the world, so I suspect the problem is more exotic.
Based on insufficient data, my first wild guess was a problem in the manufacture of the circuit board or a mismatch by a supplier in terms of the voltage regulators. But again, these engineers are too good to make such mistakes ...parts manufacturers may not have followed Boeing spec sheets of course.
But a reported fact that really caught my attention (if indeed it is a fact) is that one of the dysfunctional batteries overheated when neither charging nor discharging. This is a clue if ever there was one, but what does it mean?
Before learning of this, I thought maybe the circuit board clearances were not wide enough or there was some sort of malfunction or mismatch of the voltage regulator ICs. A supplier might have made a mistake.
But if the malfunction happened when the battery was neither charging nor discharging...wtf?
When you exclude the impossible, what you are left with, no matter how improbable, is the truth. On that basis, might other electromechanical components on the aircraft have caused inductive spikes (due to collapsing magnetic fields) in proximity to the battery circuit boards?
Circuit board clearances on the battery circuits containing the voltage regulators and short circuit protection components may have been fine, ceteris paribus...but in the presence of inductive spiking from proximate devices, could they have overloaded the battery regulation circuits, caused a polarity short and led to thermal runaway?
Interested in your views. So much want to see this miracle of engineering fixed and ready to go. They take safety so seriously I am absolutely confident they will fix it perfectly.
Edit: Inductive spike exceeds datasheet spec of voltage regulator integrated circuit?
