Electro132
- Feb 12, 2013
- 261
- Joined
- Feb 12, 2013
- Messages
- 261
Hi,
I'm trying to find out how to increase the range on an IR LED. I know some methods like
- adding more LED's;
- increasing the voltage input (i.e. instead of using a 5v batt you use a 12 v);
- adding transistors to amplify the existing voltage input into its base (i.e. using a 5v batt could increase to 1 w); and
- Using a high powered IR LED. (Currently using a 5mm 880 nm max 150 mA)
I am using a 5v batt for my IR LED circuit and while the IR LED works i cannot seem to get any result. Also, this is part of my current project but since it was a topic that i needed to get a wider audience in i was thinking this would help.
I appreciate any feedback given. Thanks
