I would like to build a 4 channel H-Bridge suitable for driving an inductive load (predominantly three-phase "BLDC" and steppers, but also for testing the reactive components of an SMPS) Rather than being a dedicated driver for any particular motor, I would like to build a "prototyping" driver for testing various motors/circuits at voltages from 20V to 100V and currents upwards of 20A/phase. Obviously 20A at the upper end of the voltage range is 2kW, a non-trivial amount of power to switch on and off into an inductive load at any frequency. I may well end up having to design/build two devices, one for higher current/lower voltage the other for higher voltage but with lower current, but I would prefer to build a single device even if it cost 4x more than 2 narrower range devices. Switching Frequency considerations are 0Hz to 100kHz.
Design priorities are as follows:
1) Robustness
2) Flexibility (wide range of voltages/currents/switching frequencies)
3) Simplicity from a Connectivity Point-Of-View
4) Efficiency ==> Note this is a LOW priority
5) Cost **Note: I include this only as a last consideration, ultimately this is a "one-off" designed specifically to save money/time/effort in testing motors and prototyping other circuits, and I really don't care if it cost $50 or $500 to build**
The first choices to make are:
Mosfets vs IGBTs for the output driver.
Complementary vs High/Low Side Drivers for N-Channel Devices.
or
a Module like:
FSBB30CH60
or
FSAM50SM60A
(These are three channel devices, so to achieve 4 channels would either require 2 modules (six channels) or 1 module + a secondary circuit.)
I would love some thoughts/input on which direction to focus on. This will be my first high power h-bridge design so any experienced input would be welcome; including an "off the shelf solution" if there is one (for instance I have several "ESCs" designed for the RC hobby industry, and while not ideal for what I want, are certainly functional for testing BLDCs I also have numerous "Stepper Drivers", again functional for Testing/Driving Steppers, but not versatile enough to suit me, but there maybe an "off the shelf" solution that would meet the project design goals, actually there is one that is close: the "SnapAmp" by Dynomotion [ http://dynomotion.com/ ], and I have not completely ruled it out if I get in "over my head" on this project. Any other "off the shelf" recommendations would be great! ).
If there is general interest in this topic I will keep this thread updated with my progress. (Realistic time frame for project completion would be Spring of 2014.)
Thanks in advance!
Fish
1) Robustness
or
a Module like:
FSBB30CH60
or
FSAM50SM60A
Thanks in advance!
Fish
