need help flip flop truth table
vead
Nov 27, 2011
473
when the value of flip flop input are known how to find out the flip flop output I want to find out the output of d flip flop
truth table
D Clk Qn|
0 0 |
0 1 |
1 0 |
1 1 |
how to find out Qn ?
Harald Kapp
14,290
First I think this is homework, so I'll move the thread.
Second: the state of Q is not important. Flip-flops are typically edge triggered. The state of a flip-flop changes with either the rising edge (clock from 0->1) or the faling edge (clock from 1>0), depending on the type of flip-flop.
You also need to know what type of flip-flop you have. There are many different types like RS-FF. JK-FF, D-FF and others. From your simple truth table one can assume you have a D-flip-flop. A D-flip-flop changes the output to the same state as the input with a clock edge.
Now:
- find out what clock sensitivity (rising or falling) your flip-flop has
- find out what type of flip-flop you have
Then you have everything tocreate a meaningful truth table.
vead
Nov 27, 2011
473
Now:
D flip-flop positive edges
clock input changes from 0 to 1 (rising edge)
when clock is rise what will be the Qn
when clock is not rise what will be the Qn
vead
Nov 27, 2011
473
Now:
when clock is rise Qn will become as D input
D Clk Qn
0 0
0 1 0 clock is raising from 0 to 1 so Qn will become as same as input D
1 0
1 1 1 clock is raising from 0 to 1 so Qn will become as same as input D
when clock is not rise what will be the Qn?
Harald Kapp
14,290
A flip-flop is a memory element. It will remember the state of Q and change only on a clock edge.
vead
Nov 27, 2011
473
i want to ask when clock is not rise what will be the Qn?
D Clk Qn
0 0 ? what will be 0 or 1 and why?
1 0 ? what will be 0 or 1 and why ?
To repeat what you've been told.
Q only changes on the rising edge of CK.
So is is unchanging when CK is high, low, or falling.
So, what value does it have? (Hint: Ask yourself what value it had)
Harald Kapp
14,290
D Clk Qn
This truth table is useless. There are no clock edges to show the change in Q. Also the state of Q depends on the state of D during the active clock edge.
Normally you use symbols to note these key elements in the truth table.
Hint:
Use e.g. ^ to indicate a rising clock edge (active)
Use e.g. x to indicate a don't care (state of the signal can be 0 or 1 without any
difference)
Use Qn-1 to indicate the state of Q shortly before.
Make a table like this:
D clk | Qn
x 0 | Qn-1 <- the state of Q doesn't change when clock is 0
x 1 | Qn-1 <- the state of Q doesn't change when clock is 1
0 ^ | ??? <- place your answer here
1 ^ | ??? <- place your answer here
You may also look up the datasheet of the7474 integrated circuit which explains the operation of a D-type Flipflop.
vead
Nov 27, 2011
473
Hint:
difference)
D clk | Qn
D clk | Qn
0 0 | ? the state of Q doesn't change when clock is 0 what will be Qn 0 or 1 and why
1 0 | ? the state of Q doesn't change when clock is 0 what will be Qn 0 or 1 and why
0 1 | ? the state of Q doesn't change when clock is 1 what will be Qn 0 or 1 and why
1 1 | ? the state of Q doesn't change when clock is 1 what will be Qn 0 or 1 why?
0 ^ | 0
1 ^ | 1
D clk | Qn
it will be Qn-1 (assuming that Qn-1 is the state Q was in some small time earlier.
why? Because that's the function of the device!
You haven't given the states on a falling edge either.
vead
Nov 27, 2011
473
ok if someone say draw the truth table for D flip flop so what is the truth table for D flip flop
Harald Kapp
14,290
That's what you're supposed to find out, isn't it?
Maybe you should try to understand how a D flipflop works. Just copying a truth table someone else has drawn will not help you. This page explains D-flipflops in detail. Please read it and try to understand what is said there. If you still have questions after that, come back here.
