bizzlemedia
- Jun 20, 2011
- 7
- Joined
- Jun 20, 2011
- Messages
- 7
Hi there,
The project I am working on at the moment revolves around a simple ring modulator circuit which I have built however I am having trouble deciding what to use as an onboard sin wave generator to act as the modulator signal (not sure If I have carrier and modulator mixed up). Basically, I have my microphone signal connected carrier input but I need something which I can include inside the same project box to produce a 30hz (aprox) sin wave to modulate the signal to produce a Dalek emulation.
555 timer chips are out of the question as I can only produce square waves with them. My analogue sin wave generation circuits look unnecessarily complicated and I need something small and simple.
I can produce a fantastic Dalek sound using my function generator as the modulator but obviously that can't be included in the finished project. Would a microcontroller do the trick? In a perfect work I would also like to be able to attach a pot to vary the frequency of the sin wave (between 5hz and 200hz)
Any suggestions would be greatly appreciated. Thanks
i
i
