Raspberry Pi V. Arduino
Dylan Wisdom
Apr 10, 2014
26
What is the main differences between what Raspberry Pi does and what Arduino does?
kpatz
Feb 24, 2014
334
In short, Raspberry Pi has a more powerful processor that runs Linux. Arduino uses a simple microcontroller that is programmed in C or Assembly. Similar in principle, but they have different capabilities and applications.
Anish
Feb 5, 2011
46
In simple words,
Arduino ~ Nokia 3310
Raspberry pi ~ nokia lumia 1020
ranger306ci
Apr 5, 2011
2
IMO, arduino is easier to use from the get go. The language and setup are simple.
However, if you can code in python, the pi is more powerful.
For most imbedded projects, the arduino is plenty.
Thedarkb123
Apr 15, 2014
29
For most projects you don't even need an arduino, just an AVR and maybe a crystal.
They really fooled you didn't they?
That's C++ you're coding in. The setup might be simple, and the examples may be simply coded, but don't let that fool you. If you start looking at other people's library routines you'll find out real fast.
Dylan Wisdom
Apr 10, 2014
26
Could you use both Arduino and Raspberry Pi on the same project? Could they work together?
kelvinmead
Nov 22, 2011
16
arduino is better at external hardware, buttons, leds, integrating with permanent solutions
raspberry pi is better for coding with, plus you can see what you are doing.
