Lance Mannion
- Jun 9, 2014
- 37
- Joined
- Jun 9, 2014
- Messages
- 37
For those of you who helped me with the sensor project for my friend's mini golf course, a new project has arisen
My sensor worked fine and everything was cool - then an electrician accidentally fried the boards on the 19th holes and now the alarms in the clubhouse no longer work
This stuff was installed many years ago. There is no documentation and no one to contact who knows anything about it. I told my friend that he should consider something new and SIMPLE.
So here's the new project. His requirement is that once the golf ball passes the sensor, an alarm would be triggered in the clubhouse that indicates a hole-in-one on the 19th hole was made and that the person gets a free game. The alarm in the clubhouse would continue to sound until the employee presses a reset button. This process would repeat for the next hole-in-one.
I have the following circuit from the sensor
When the sensor is clear, the voltage on the white wire is about 200mV. When the sensor is triggered, the voltage jumps up on my volt meter to around 600mV for a split second. I need the voltage on the white wire to trigger the alarm (which will have it's own 12V power supply in the clubhouse). I then need a momentary switch that the clubhouse employee pushes to shut the alarm off.
I have a few ideas but since I'm new at this I don't want to go down a rabbit hole if there is an easier design I should be concentrating my efforts on considering he wants to get this working on his course asap. Obviously, the white wire would need to trigger the alarm but what components do I need that would see a 200mV signal as 'off' and a 600mV signal as 'on'? Then how do I keep the alarm on once the voltage on the white wire drops back to 200mV (almost immediately)?
Any help would be greatly appreciated.
