partyanimallighting
- Oct 22, 2012
- 335
- Joined
- Oct 22, 2012
- Messages
- 335
Hi everyone, I'm back again with a problem that I'm having with a large fog machine that is used for concerts and large stage . jobs. The unit consists basically of a heater block, a pump that forces the fog fluid through the heater block from a fluid reservoir bottle, and a circuit board which controls the unit manually or via DMX. When the unit is plugged in, the display on the remote will state "WARMING UP" and, once the heater block reaches the appropriate temperature, the display will then display "READY TO FOG". When the MANUAL button is pressed on the remote, this switches on the fluid pump and the fog fluid is forced through the heater, creating a dense cloud of fog. The unit however, seems to have a problem with the pump output. When the MANUAL button is depressed, the pump does not output at full output and barely pulls fluid from the reservoir bottle. I tried bypassing the circuit board completely and I hooked up the pump directly to a 110V supply and it works fine so I believe that the pump output on the circuit board may be faulty. I checked the voltage at the pump terminals with the pump removed from the output and I am getting 110V whether or not the MANUAL button on the remote is depressed. I then hooked up a small 30W 110V lamp to these terminals and the lamp lights when the MANUAL button is depressed. I also removed the pump completely, disassembled. serviced and reassembled it and it works fine with a direct 110V input. Any ideas?
