Supercap2F
- Mar 22, 2014
- 550
- Joined
- Mar 22, 2014
- Messages
- 550
Hello Everyone!
Well as the title states, I finally got an oscilloscope. It's a 60MHz Leader 8060, which I got off of ebay for about $110. So first of all does anyone know where I can get it's user manual? I contacted Leader and they didn't have it, but they did give me the manual for some 'scopes like it. Or maybe if anyone has it they could send me a scan?
So, I found out that you have to adjust your probes to get the most accurate reading. The way this is done, is you hook up your probe to the 'scopes calibrating signal, and turn the variable capacitor on it tell you get a good sharp signal. Is all that right?
I have a BK precision PR-40 probe (actually it's my Dads). And it has a 15pF-40pF capacitance range. Does that mean that the input capacitance on the scope has to be somewhere between 15pF-40pF for the probe to get a accurate reading?
The Leader scopes before and after the 8060 have about a 20pF input capacitance. So I am assuming that the 8060 does too (or is really close to it). So if it does have a 20pF input capacitance then the probe should work good with it. Right? But if it does not, and I hook up the probe I have to it, will anything bad happen? Besides not getting a accurate reading.
Thanks Guys!! I may have some more question later.
Dan
Dan
