roberto8978
- Sep 6, 2014
- 12
- Joined
- Sep 6, 2014
- Messages
- 12
So, I got a set of logitech x-210 speakers 4 or 5 years ago(probably more). They are not under warranty any more. About 2 years ago, they started to behave erratically. The led light that lights up when the speakers are on, sometimes, went off (as well as the sound). Or when I tried to turn the speakers on in the morning, sometimes they wouldn't and sometimes they would. And then, one day they finally cracked for good. They never came on again.
So the set consists of a pair of speakers and a subwoofer with a built-in amplifier. It also has a remote volume control (with an on/off switch too). The speakers can be disconnected from the subwoofer and be used separately (I've tried them and they work).
If it was all working properly they would be set like this: the speakers connect to the subwoofer and the subwoofer connects to the pc , to the remote volume control and to the wall's ellectrical socket.
I've dismantled the subwoofer and amplifier. The transformer is giving out 15V, and is labeled for 13.5V. I can't see any burnt out components on the pcb. The only thing I see that's different is a component labeled "TFA9842J", wich has a kind of white paste on it's back, but i assume that's some kind of thermal paste.
I've also dismantled the remote volume control and there doesn't seem to be anything wrong with it either.
If needed I can post some pictures of the pcb, remote volume control, etc..
What should I do?
Thanks in advance
What should I do?
Thanks in advance
