flippineck
- Sep 8, 2013
- 358
- Joined
- Sep 8, 2013
- Messages
- 358
Referring here to the sort of LED lamp which is commonly available in supermarkets etc, usually with a Bayonet or Edison Screw type connection, for domestic 240V AC use, and using a multitude of small discrete LEDs (rather than 'LED filament' or other new fangled technology) I guess similar is available in other countries albeit with a different voltage rating to suit the mains in the locality..
I was asked a while ago to fit a chandelier that used these LED bulbs but the customer wanted it to be dimmable.
I found that the majority of commonly available mains LED bulbs, were specifically specified as being non-dimmable.
So, I went to the trouble of sourcing suitable LED candle bulbs (these were 3W ones with maybe 15 or 20 individual LED chips inside) that said 'dimmable' on the packaging.
Rigged everything up and it didn't work.
Turned out, that most dimmer switches work by chopping off a variable chunk from the back end of the sine curve. Full brightness, you get a full sine wave, as you go dimmer, the switch leaves the sine curve to rise from initial zero crossing, but then sharply drops the voltage to zero mid-wave until the next zero crossing.
For some reason this trailing-edge chopoff doesn't work with most LEDs but, they work okay if you chop off the FRONT of the sine wave!
Apparrently the trailing edge chop is a characteristic of the commonly available traic-type dimmer. Turns out there's another kind of dimmer switch circuit that uses a transistor instead of a triac, and that type does a leading-edge chop on the sinewave.
Managed to get one of these, and it worked beautifully.
I might have got trailing and leading edge and transistor/triac mixed up in the above description but hopefully you get the gist nonetheless
Now, I have another chandelier. This one is fitted with six 4W mains LED bulbs, these say 'non-dimmable' on the packet.
I just wondered what the difference was electrically (differences in the little power supply in the base of the LED?) and, although maybe not commonly available off-the-shelf in an electrical retailers, would it be possible to rig up some kind of bespoke circuit for dimming this type? Despite the labelling? Ideally without resorting to plain rheostats
Sorry I've only got 6 of these bulbs & they're all in use otherwise I'd smash one up to inspect the circuit inside & provide pictures etc. They're 4 Watt LED candles from ASDA. E27 base.
