I'd like to incorporate this SSR (PF240D25http://www.mouser.com/ds/2/93/p_f-16841.pdf) into a custom PCB, protect it using an 15A fuse and provide in/out terminal blocks for connectivity/pass-through (load/neutral/ground). This is part of a home automation project and my first entry into AC circuit design. I'm essentially creating a WiFi-enabled motion detection faceplate to control lights throughout the house (120v/60Hz).
My initial research indicates that I would probably need 4oz copper thickness with ~6+mm trace between 'terminal block->fuse->SSR load' if I were to provide routes on a PCB that could sustain a 15A load. Not feasible for my purposes and price range. I plan to use stranded copper cable to complete the connections. Am I correct in this conclusion and is this the safest way to handle high current on a PCB? Should additional copper be available surrounding the pads on the PCB (planning on 0.06" outer/.04 inner) to support higher current or will standard dimensions work assuming the pads are sized appropriately for the through-hole AC components?
The max amount of current through the SSR should be on par with a single 100w bulb (~0.83A) and no more than ~2A for multi-bulb fixtures. Based on the datasheet for the SSR, temperatures seem to be pretty high for mounting it in a single/double gang box. Would an SPST relay be more appropriate in this situation? Although more expensive, I'd prefer the SSR for it's simplicity and decoupling nature.
For clarification, the PCB for AC is on a standalone PCB. Shielded cabling is used to connect it to a DC control board / MCU.
