Hi,
Let me start off by introducing myself! My name is Chad. I had several years of electronics classes 10+ years ago but I went threw stage 4 cancer/chemo which wiped out most of the knowledge I had of electronics! Though I typically begin picking up on the things that were wiped pretty quickly.. So please be patient with me!
Anyway, I have a variable power supply, used to test/break in motors and run accessories (motor & tire lathe's) for Slot Car's.
The power supply as it came from the manufacture had a 6.3v 6a transformer. I needed a bit more power, so I installed a 12.6v 8a transformer in the case, as well as increased the capacitor to a 4700uF (I don't remember what size the original capacitor was).
The Linear Voltage Regulators that came with the power supply are LM350T's, 3 of them wired in parallel giving me 9a capacity. But the power supply is designed to use the case as a heat sink and it runs REALLY hot, there is no powered fan to move air over the case. I wanted to see if there was something I could do to cool the power supply down, so I started looking at the components and found that there is a Linear Voltage Regulator LM388T available that has basically the same specs as the LM350T's, except they are rated at 5A. So I thought I would switch out the LM350T's for the LM388T's there by increasing the amount of amp capacity and hopefully they will run cooler?
Is that a valid thought? Also I don't remember why I upgraded the capacitor, but is the 4700uF capacitor good? or should that be different?
As you see in the picture, they had a resistor soldered between the 1st and center pin of the linear Voltage Regulator, what is the purpose of that resistor?
Again I apologize if these questions are dumb, but I'm kind of re-learning everything..
Thanks in advance for the help!
-TheChad
-TheChad
