Your call... That large input capacitor will smooth out the input voltage, so instead of varying between say 13V and 12V, it may only wiggle about from 12.25V to 12.75V. **Please note I made those numbers up...Great! One less component to worry about!
I was doing some more testing today and it looks like the voltage jumping around may be due to a loose connection on the potentiometer... One of the colder tabs is loose (Which is why I am ordering a new one), and I put a drop of solder on it to hold it in place until the replacement shows up.. I was testing today and the voltage would just completely at random spike to like 14 volts..
So I messed around with that wire and when it was making good contact, the voltage was solid, didn't move more than .01v over a 10 minute period..
So it seems I may not even need the 100uF capacitor, I may throw it in there anyway, but it looks like that wasn't the underlying problem..
The bigger cap will help flatten the input, and will help maintain that flattened input when you are drawing a lot of current. I would not worry about the input one at all anymore.
The 100uF capacitor that you have is 'helpful', in that it would filter out the smaller little spikes that occur. This would not do much with large jumps from 5V to 12V if it was any more than a fraction of a second. If you have a solder braid, or solder pump, you could remove the wire from your potentiometer, clean it off and rejoin it. That may solve the need to replace the whole part.
That extra bridge idea wont make your system a half wave.I changed the original capacitor from I believe 3500uF to 4700uF, which would have made since I went from a 6A Transformer to an 8A transformer..
But maybe I didn't go large enough? Though maybe it's not affecting anything... I assume if the capacitor was not large enough it would cause pretty noticeable voltage droops?
Before I go and order the new 10v transformer... This idea of installing another rectifier.. I can pick one of those up at Radio Shack.. If that a viable solution? From the sound of it, it would drop my current 14v down to 12v which is what I hoped to accomplish with the 10v transformer. How would I hook that up? Wouldn't that effectively make it a 1/2 wave rectifier instead of a full wave rectifier, thus creating bigger droops between phases?
-TheChad
The first bridge will rectify the full wave, and then pass DC to the second bridge. This will result in the second bridge only using 2 of its 4 internal diodes.
To do this, you need to disconnect the + and - from the first bridge and connect it to the AC1 and AC2 of the second bridge. The second bridge will then have its + and - connected back to the rest of the circuit.
