Ernest George
- Jul 18, 2014
- 71
- Joined
- Jul 18, 2014
- Messages
- 71
Hi Folks!
I'm in the process of trying to add WiFi to a project and it turns out I need a RS232 converter such as a MAX232 chip.
The problem is I can't make heads or tails out of all the datasheets so that I can source the darn thing and add it into my circuit. As you may have guessed, I am not an electronics engineer.
The WiFi board I want to incorporate puts out UART 3.3v TTL
I need to convert that signal to old school RS-232 and run it elsewhere. That's all I need to do.
You'd think this would be simple but every datasheet seems designed to make this as difficult as possible. I found one device that I thought would work as it accepts TTL/CMOS inputs which, as I understand it, it what the chip needs to support on the input side. Unfortunately, the datasheet says that it generates +/- 5.5v for the RS-232 output voltage levels.
I thought RS-232 operated anywhere from +3 to +15 volts - or even higher. So, this causes me to question whether this chip is correct.
All I need is a single driver chip, preferably one that's automotive temperature rated that accepts UARt 3.vv TTL and outputs proper, old-school, RS-232. Can anyone cough up a good part number to use for that?
