Rui Monteiro
- Nov 3, 2014
- 17
- Joined
- Nov 3, 2014
- Messages
- 17
Hey everyone,
Some months ago I started to learn by myself electronics, so my level of knowledge is probably basic.
I'm projecting on multisim one ESR meter. Basicaly the big diference between my project and others we can find on Internet is that mine is intended to work with one frequency of 20 MHz (sine wave). My oscilattor is one colpitts transistor oscilattor, inductor one. After this I have one buffer and amplifier to inject the signal into the cap under test, using one constant current source. Because, frequency is very high, the reactance of the capacitor under test will be very low, thus the final impedence will be aproximatly the ESR value for the lowest cap of 1uF. Now that we know the resistance of the circuit under test and we also know the current, lets say 100uA, the voltage at the the capacitor terminals will be aproximatlly one multiple of ESR value. To measure this voltage, since I cant find one opamp with high gain at this frequencies, I'm amplifing the voltages at the cap terminals with transistors. Now I need to transform the ac voltage peak to peak into one equivalent dc voltage, to make one opamp instrument amplifier to excite one voltimeter. So I am trying to implement peak detector with one pin diode in series with one parallel capacitor and resistance. And this is where the issue happens. Whenever I link the peak detector with the previous circuitry, after turn the simulation on, the 20MHz disapear and it seems that appear for some short periods of time others oscilations with low amplitude. If I disconnect the peak detector from the circuit, everything seems to be working fine.
Does anyone know what could be wrong? I suspect that for some reason I dont know, part of the colppitts oscilations are being absorved via ground by the peak detector, but as I said before, I'm rookie in this kind of stuff and I really dont know how to solve this issue.
I will aprecciate every help. Thank you very much in advance.
Rui
Rui
