Hrm.. if that's the case, it would appear to have a common ground as well which is not cool...
You had stated that you originally connected the + of the meter to the center tap after the diode, and the negative went to the negative of the existing capacitor. I would leave your setup the way it is.
It would be nice to have the negative power lead for the meter connected as well before the bridge... but if the negative lead for the voltage test is common, or internally tied together, you may end up creating a short within your power supply.
Okay, I just tried connecting it the way you suggested... Center tap->Diode->Positive lead on meter | Other lead from transformer-> Negative lead on meter... Zero Volts.
When I check with the volt meter. Touching the other side of the diode and one of the other taps on the transformer I get 0V. However when I touch the negative lead on the volt meter to the negative lead on the large capacitor, I get 7.32v.
So something isn't right.... Am I suppose to have a diode between the other tap on the transformer and the negative terminal? (2 Diodes)
I did test again the 2 (+ & -) leads to power the volt/amp meter, the positive MUST be connected for the meter to turn on, however the meter turns on with ONLY the + lead connected....
So I guess the negative lead in the Amp/Volt meter harness is the common (negative) for the whole meter..
To test this, I disconnected the negative terminal from the DC/DC Converter that goes to the Negative (Common) terminal of the Amp/Volt meter and the meter does not power on with only the positive connected, when I plug the Negative back into the DC/DC converter or connect the negative from the power harness to the negative on the main capacitor or the negative terminal on the DC/DC converter, the meter powers on....
So I guess that shows that the negative (common) in the meter is all the same. While there is 2 wires, its the same circuit..
-TheChad
