Well, that's a +1 ...That PCL relay is 5A at 32v however.
I've never tried it. The problem with DC loads is the inductive kick-back from the load (the motor) which causes arcing, especially if the contacts move slowly or don't separate very far. I think this would worsen by a factor of four for every doubling of the voltage.@KrisBlueNZ , you have a lot of experience under your belt... what do you think of using a 12V 30A relay to control a 24V 2A device?
Sounds good Kris, Thank you.I've never tried it. The problem with DC loads is the inductive kick-back from the load (the motor) which causes arcing, especially if the contacts move slowly or don't separate very far. I think this would worsen by a factor of four for every doubling of the voltage.
You should have a 1N540x across each contact that could break the circuit to the load. Is the relay rated for an inductive load? I don't know whether you would be safe. I would buy the right part. You'll need one new relay anyway won't you? Might as well get two SPDT relays with 30V contact rating.
It will. The Diodes are merely added protection for the relay.I just tested it and appears to be working very well.
Your welcome. Sorry it took so long to get you a simple answer. I completely missed the rating on the pair of relays you had already :sThanks for your help Gryd3!
