- Joined
- Nov 28, 2011
- Messages
- 8,393
I'm still not convinced that it's meaningful to describe a transistor as voltage-controlled.
It's certainly true that voltage is needed in order for anything to happen - you need a base-emitter voltage source and a collector-emitter voltage source - but that is just due to the nature of voltage and current.
No component (apart from special components that can store energy) can do anything without an applied voltage. No current can flow in a resistor unless a voltage is applied. You can't apply a current to a resistor without also applying a voltage. It's simply natural cause-and-effect in the real world.
I pointed this out back in post #123 but I'll spell it out again.
An LED won't light unless voltage is applied. Yet LEDs are described as current-driven, for two obvious reasons: (a) it's not normal or useful to connect a firmly defined voltage, such as a battery, directly across them (unless the current is limited by the battery's internal resistance, in which case you're applying a current, not a voltage), and more importantly, (b) the primary quantity that varies (brightness) varies roughly in proportion to the forward current, and not the forward voltage.
In this sense, a transistor is the same as an LED: you don't connect a battery directly across the base-emitter junction, and the primary quantity (the collector-emitter current) is proportional to the base current, not the base-emitter voltage.
You could argue that the collector voltage (in a common emitter circuit) is also a primary quantity, but it doesn't vary in proportion with the base-emitter voltage either; it varies inversely with the base current. So that doesn't help the argument that a transistor is voltage-controlled.
You might be able to argue for a transistor being voltage-controlled in an emitter follower circuit, but I would argue that it's the circuit, not the component, that is voltage-controlled.
If there is any difference between how those two criteria apply to the LED and to the transistor, please let me know what it is.
If there isn't, then saying that a transistor is voltage-controlled doesn't tell us anything about transistors specifically, because by that definition, every component is voltage controlled.
What I think is more relevant is the mechanism by which the transistor operates. This is something I don't understand - doping, depletion region etc don't mean much to me. But as I pointed out in post #116 (which no one answered directly), I was interested in the explanation posted by Ratch in post #85. He wrote:
From my limited knowledge of semiconductor physics, I thought that IBE was needed to bring charge carriers from the emitter into the base, where they can then be attracted to the collector. If that's true, then IBE causes ICE to flow; in that case, I for one would say it's most meaningful to describe a transistor as current-controlled. Given the understanding that voltage is needed to cause current to flow (as it is with other components).
Can someone please set this last point to rest? That is, does IBE cause ICE or is it caused by ICE?
He seems to be implying that IB is an unfortunate by-product of ICE and should be considered a fraction of it; the fraction being 1 / hFE. This differs from the usual explanation that IC is IB × hFE. He seems to be implying that IB is caused by ICE.In a BJT operating in the active region, the Vbe is used to control the charge carriers diffusing into the thin base area where they are whisked away into the collector circuit by the collector voltage.
Unfortunately, not all the charge carriers are captured. A relatively small number of charge carriers make it into the base circuit where they become waste current because they do not contribute to the collector current. This waste current is a relatively constant proportion of the collector current and is roughly the inverse of BETA.Ratch
