If I remember correctly, the internal and external rheostat were connected in parallel for the final product. (Please correct me if I'm wrong)Hey guys!
Well been using the new power supply for a few months! It's been working fantastic! No heat regardless of amp/voltage!
My only problem at this point is that it's very hard to adjust voltages minute amounts, a tiny bump of the knob jumps the voltage...
Today I took a measurement with the knob (50k ohm rheostat) on the front panel turned all the way up, with the internal rheostat turned down to limit the voltage output to 12.6v Max, I measured the ohms with the meter set on 20k ohms, I got a reading of 2.99, which means ~3000 ohms, right?
The internal rheostat and the external rheostat are both 50k ohm.
Since my maximum reading was ~3000 ohms, if I were to get a 3k ohm external rheostat, would that give me much more control over the voltage range?
Thanks!
-TheChad
You can add a resistor in series, or in parallel to the rheostat to narrow the output voltage range quite a bit.
So...
Step 1: Determine the Max, and Min voltage you want to be able to set.
Step 2: Using only 'one' of the rheostats, adjust the power supply to the lowest setting you want. Then measure the rheostat.
Step 3: Using only 'one' of the rheostats, adjust the power supply to the highest setting you want. Then measure the rheostat.
From the information in Steps 2 and 3, we can modify the adjustment rheostat to give you control from the min - max value... which should allow you to have a more gradual control. Additionally, you could use a secondary external rheostat. One for rough adjustment, and another for fine adjustment.
The path you take is up to you. Let us know!
. And I'm glad you are enjoying it. You put a lot of work into that thing, it's always nice to have a project work out![]()
Hrm.. well, here's where it gets a little interesting then.
With the internal rheo set the way it is. The output is now limited from 1.2V to ~12V correct?
In order to get more precision as you adjust the dial, you either need to work with 2 external rheostats, or you need a replacement external rheo that has a greater travel distance.
How 'fine' of a control do you want to achieve?
Not really... the internal rheo results in limiting the 'total' resistance of both that result in 12V max... you would have the same result with a single rheo with a 240 degree range and a max of 12 desired Volts.If I were to remove the internal Rheostat from the picture and tested the external rheostat to be at the appropriate Max voltage of 12.6v at say 30k Ohms, would getting a 30kohm rheostat not give better control/adjustability because the additional 20k ohms of range is simply removed from the picture?
Narrowing the range will certainly help.If I reduced the Max voltage on the internal Rheostat down to say 8v, is that going to give me better control on the external rheostat?
Is narrowing the range not going to help in this case?
Thanks!
-TheChad
1.2 - 8V will almost double the precision.. so instead of 0.05V per degree, you would get 0.027V per degree. Of course you could not go past 8V then...
Oh wow... Then I'd be willing to bet that adjusting the internal rheo to limit the output voltage to a lower value will give you more accuracy. It's free to tryWell, at this point it doesn't seam like I have any other option, unless I want to go to a multi rotation rheostat, which I don't think would be very good for my application...
I really don't need 12v, I set it to 12.6v just because the transformer said 12.6v so I figured for consistency I would set the max output to 12.6v.. When testing motors I am always in the 3-4.5v range, when running armature and tire truer, I set it to 4.8v. So really I don't really even need to go over 6v, but it's nice to have the additional range to rev a motor for testing from time to time. If I were to run any of my fast motors at 12v with no load for more than a fraction of a second it would likely have catastrophic results! (Spinning at well over 200k RPM)
In my case I needed the full range of voltage available. The 10K is the main control and the 470ohm is a fine control.What's the point of having a small value pot at all? Why not just put in a 10k ohm resister in series of the 470 OHM pot?
Yes - but that's no problem.By using 2 pots in series like that, you would also not be able to turn the voltage down to minimum voltage with out turning both pots down to "0" right?
-TheChad
Time to throw math at youOkay, today I measured the internal pot and external pot... (Disconnected from each other)
The external all the way up measures ~44 Ohm, the internal pot all the way up measures ~43 Ohm
All the way down they both measure "0"..
With the internal pot set @ ~17 Ohms, the voltage is @ 12.6v.. (External pot disconnected)
I know I may sound repetitive and I apoligize for that, but I don't understand why if I used a 20k ohm external pot (still wired to the internal pot set @ ~17 Ohms), why that would not give me better control?
Narrowing the range of the external pot would seem like it should offer better/narrower path to control the range?
With the pots wired together, when the external pot reaches ~17 ohm, the rest of the range is ignored right?
Thanks!
-TheChad
If you get a potentiometer that is 40K +- 10%... that just means that the value of the potentiometer could be 44K... or 36K (or anywhere in between)I've used pots that "click". Which would make control much easier...
But I don't know if they make them with built in switches and they were of the "infinitely adjustable" type..
Maybe I should try a different knob!
My knob is a 1.25" knob..
I found that one pot I posted above (http://www.mouser.com/ProductDetail/CTS/450T328F503A1C1/?qs=/ha2pyFadugAOy/rJgGbtXoiCKVSBiSimKSS8BMYOKvz0mob2XN%2bug==) that goes a 320-degree range.. What about tlowrance? Will a pot with less tolerance be more accurate?
Thanks!
-TheChad
