around 100mA is the current to be drawn from the switch, U21 can carry 350mA , at 3.3V , and the regulator can provide 300mA currentThe switch inside U21 is always in one position or the other postion. In other words, A is always connected to either B0 or B1. There is no option for "no connection".
U21 is an analogue switch and is not really intended to switch power. How much current are you going to draw from it?
If you want a voltage of 0V/1.0V/1.5V there may be an easier way to achieve it. Post the schematic of the regulator part of the circuit.
Regulator 1 is connected to provide 1.5V and regulator 2 to get 1V respectively. 1.5V and 1V is required to operate a device in full voltage (1.5V) and low voltage(1.0V)around 100mA is the current to be drawn from the switch, U21 can carry 350mA , at 3.3V , and the regulator can provide 300mA current
OK.around 100mA is the current to be drawn from the switch, U21 can carry 350mA , at 3.3V , and the regulator can provide 300mA current
Yes, I guessed that.Regulator 1 is connected to provide 1.5V and regulator 2 to get 1V respectively. 1.5V and 1V is required to operate a device in full voltage (1.5V) and low voltage(1.0V)
Why used MOSFET instead of BJT ?View attachment 18740
This is the simpler way to do what you want. This is a widely used trick. You only need one regulator, and no analogue switch.
When the voltage select line is low, the MOSFET is OFF and the output voltage is set by R105 and R113. Since the ADP171's reference voltage is 0.5V, the output voltage will be 1.0V.
When the voltage select line is high, the MOSFET is ON, and it connects the new 10 kΩ resistor in parallel with R113. Therefore there is 10 kΩ from the output to the ADJ pin, and 5 kΩ from the ADJ pin to 0V, so the output voltage will be 1.5V.
The enable pin operates as normal.
yesYou want to use two regulators and an analog switch IC, instead of just one regulator?
r u in facebook ?What about it? It will work.
