Test bench power supply
slanwar
Mar 5, 2015
18
Found this power supply article on nuts and volts from march 2007 and I would like to build one:
I'm having a bit of an issue to find some parts like the transformers, I was looking to find exactly the same parts.
BobK
Jan 5, 2010
7,682
It would help if you told us what the parts were, or at least linked to the article.
Bob
slanwar
Mar 5, 2015
18
page47image12584
slanwar
Mar 5, 2015
18
PARTS LIST
0-20 VOLT BOARDS DESCRIPTION
❑T1 120V primary, dual 44V center tap secondaries @ 1.5A
❑ D1,2 3A, 100 PIV
❑ D3,4,5,6 1N4002
❑ C1 4700 ìF/35V *
❑ C2 100 ìF/35V *
❑ C3 0.22 ìF
❑ C4 10 ìF/35V
❑ C5 22 ìF/35V
❑ C6 0.1 ìF
❑ R1 0.1Ù 1% 3W
❑ R2 16Ù
❑ R3 750K
❑ R4 2.7K
❑ R5 12K *
❑ R6 240Ù 1%
❑ R7 100K
❑ R8 910Ù
❑ P1 500Ù
❑ P2 5K
❑ P3 200K
❑ P4 200Ù (Mouser #531-PT10V-200; $0.42)
❑ Z1 1.25 volts reference (Mouser #511-TS821A1Z; $0.64)
❑ IC1 LM317K (Mouser #511-LM317K; $2.10)
FIVE VOLT SUPPLIES BOARD
❑T2 120V primary, 9V secondary@ 1.5A
❑T3,T4 120V primary, dual 9V@ 65 mA secondaries
❑ C1 4700 ìF/16V
❑ C2 10 ìF/16V
❑ C3,5,7,9,11 0.1 ìF
❑ C4,6,8,10 47 ìF/16V
❑ BR1 2A, 100 PIV
❑ D1,2,3,4 1N4002
❑ IC5 7805
❑ IC1,2,3,4 78L05
MISCELLANEOUS
❑ S1 SPST toggle switch
❑ S2 4PST toggle switch
❑ Panel Meters 200.0 mV
slanwar
Mar 5, 2015
18
The first one on the list I have a hard time to find one with the exact same specs
"T1 120V primary, dual 44V center tap secondaries @ 1.5A"
Arouse1973
Adam
Dec 18, 2013
5,178
If you can find one with a larger current rating that will be fine. Is this the problem your having.
Adam
BobK
Jan 5, 2010
7,682
If you do find such a transformer, it will probably cost you more than buying a complete bench power supply.
Bob
BobK
Jan 5, 2010
7,682
Actually I looked, and dual supplies do not come that cheap.
I think your best bet would be to get a toroid core of the appropriate size and wind your own transformer.
Bob
slanwar
Mar 5, 2015
18
I found a few Chinese power supplies on eBay rating 30v for $33 free shipping ---from China :) or they are really bad or they are really cheap
BobK
Jan 5, 2010
7,682
Yes, I found cheap singles, but no duals for less than about $180.
Bob
slanwar
Mar 5, 2015
18
Bob
When I was a teenager I used to build my own transformers, good times, everything electronic was expensive so we had to improvise.
slanwar
Mar 5, 2015
18
I end up to buy one on Ebay for $80, says "made in USA" but I have to see to believe.
BobK
Jan 5, 2010
7,682
One what? Transformer or dual supply?
Bob
