Why Low output voltage for wind turbine?
Status
Not open for further replies.
Luiz
Apr 3, 2015
3
Hello everyone,
I recently built a small wind turbine. I’m using a 12v 3-phase AC motor which connected to a charge controller and then to a 12v battery bank. On my charge controller I can see that even in a strong wind my turbine never puts out more than 10v. The highest value that I recorded was 10v and 18A at 40mph wind. Does anyone know why the system is not putting more voltage? So I can only produce (10x18=180 Watt) with this system? Is there a problem with my controller? Sorry if I’m missing some basic concept, but this is something new to me.
Thanks a lot
davenn
14,480
hi Luiz
welcome :)
just my initial thought
not all motors make ideal generators, maybe you should be trying an actual generator
others may have some ideas as well
Dave
Kiwi
Jan 28, 2013
506
I would agree with davenn on this.
Just like dc generators don't make good motors.
duke37
Jan 9, 2011
5,364
I agree with davenn and Kiwi.
AC induction motors have no way of generating a magnetic field on their own. They can sometimes be encouraged by loading with capacitors but a complex control system is needed.
DC is needed so use a DC generator.
Luiz
Apr 3, 2015
3
hi Luiz
welcome :)
Dave
Thanks for the quick response. I forgot to mention that I’m using a permanent magnet generator that is made for wind turbines. This generator is called Freedom PMG made by Missouri Wind and Solar. According to many reviews this is a good generator that is capable of producing a lot of power. I think that my voltage problem is related to something else.
Thanks again,
Luiz
davenn
14,480
Thanks again,
Luiz
so you changed your system without telling us ?? that's not what you said in your opening post was it ?
Dave
Luiz
Apr 3, 2015
3
Dave
Hi Dave,
Is still the same system. I have been using a 12v 3-phase AC generator made for wind turbines. I just forgot to mention that it was an actual generator on my first post.
Your charge controller is probably using Maximum Power Point Tracking (MPPT) and has determined that the maximum power is available when the load causes the voltage to drop to this point.
duke37
Jan 9, 2011
5,364
If you are stuffing 18A into a 12V battery and only getting 10V, then you have a shorted cell.
Status
