Hi!
I'm working on a 120 ohm load cell. I decided to use an INA125 to power the bridge (3.4V circa) and to amplify output signal. The full-scale bridge output is +/- 1.06 mV and the initial offset can be in the +/- 1.94 mV range. In order to compensate this initial offset (due to tolerances and temperature) I decided to use a potentiometer in parallel to the bridge. Because the output of the bridge can be positive or negative, the output is referenced to midsupply (3.4/2=1.7 V). (My ADC range is 0-3.6V)
My issue is: how can use INA125 IAref terminal to obtain 1.7 V offset? First I have thought to operate with a voltage divider and a buffer which output is connected to IAref, but resistors must be very accurate i.e low tolerance and TCR. (In my application I have to pay attention to thermal effect).
Another solution I have thought is to use the potentiometer of the bridge in order to obtain an initial 1.7 V offset. In other words, instead of nulling the bridge I can move the wiper until the output is 1.7 V, but I don't know if this method produces a bigger non-linearity.
What do you think about? What is the best solution? Have you other ideas?
Thanks!
Thanks!
