Hello Everyone
I am currently experimenting with the 74HC393 ripple binary counter. Every time a reed switch activates it causes the 74HC393 to increase its count. After playing for some time and discovering lots of false positives I realised that I needed to debounce the reed switch before it got to the IC counter. With that in mind, I built a bouncing circuit using a RC bridge coupled with a 74HC14 Schmitt Trigger and now the counter is counting perfectly.
However, I've a new problem. I would like to use the master reset function, the datasheet says that if I make the reset pin active HIGH then everything should reset. That is, all outputs return to zero. I have tried making this pin momentarily high by touching the pin with 5v but this seems to short out my circuit and of course my microprocessors reset do to power loss.
I have checked and double checked all connections and there is nothing obvious which could cause a short so I guess that it must be something internal in the 74HC393.
Any idea what I am doing wrong. I can post a schematic if necessary,
PS: Not sure if it is relevant but I am only using two bits of the counter, the others are left floating. All unused inputs are routed to ground.
Once again, I welcome all comments and thank people for helping me with my beginner questions.
Thanks
Amanda
Thanks
Amanda
