I have a small Solid State Tesla Coil I'm working on
Thank You
P.s. High frequency set up!!
The problem is the back emf from the primary winding is entering the MOSFETS and killing the back emf you are expecting from the secondary.
You need a higher voltage MOSFET
I'vTry a 800v transistor
Hello
Is this 2-6 Amps what you are expecting as far as current goes. What is the primary resistance and inductance, do you know? Or can you give me the number of turns and dimension of the former it's wound on.
Thanks
Adam
Hello
Thanks
Adam
I make the inductance approx. 10.8 uH for an air core. (r^2 * N^2) / (9*r) + (10*l). r = radius of coil, N = Turns, l = length. What core material are you using?
Adam
Adam
Its messy right now but it's going through a lot lol
Ok so the first thing to do is sort out the heating issue. The second issue is what Colin just mentioned, this won't work very well. Where did you get the coil design from?
Adam
Do you have any heat sinks fitted to the MOSFETS?
Adam
