5 Ways to Harness Free Energy
Status
Not open for further replies.
Amlan Panigrahi
Jul 9, 2015
1
Hello, I was just helping my friend to create this inverter circuit to store free energy, generated from the solution of bleaching powder, and hence use it to light up a bulb. Here is a guide that might help you:
http://www.techlegends.in/5-ways-to-harness-free-energy/
Could use some suggestions to try new things with this setup
Gryd3
Jun 25, 2014
4,098
Maybe not ... if one has a free source of bleach, and aluminum, and copper - to be liberated from the tyranny of corporate power utilities.
I guess it depends on what you consider to be 'free' energy.
I look at free energy and something that does not consume resources to generate electricity.
Fossil fuels obviously consume resources. Hydroelectric has an adverse impact on the body of water it's placed in to varying degrees. Wind and Solar are 'close' but still consume a resource... ie, solar panels require surface area that consumes light that could otherwise be used on plants. So I don't think there is ever going to be a 'free' energy, but perhaps a more efficient energy or a non-invasive method of converting energy to something we can more readily use.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
What a COS the link points to. The author claims "Each cell will produce about 1.3 to 1.8 volts depending in the concentration of bleaching powder in the cell. The current flowing will be about 300mA to 600mA in each cell." Then he goes on to say this: "Hence, 10 such cells in series will give you about 13-18 volts and the current will be about 3-6 ampere." Okay, I get that ten cells in series maybe produces 13 to 18 volts, but how do ten cells in series produce 3 to 6 amperes of current when each cell individually produces only 300 mA to 600 mA of current? Clearly that isn't going to happen. Nor are aluminum, copper, and calcium hypochlorite "free" for the taking at your local hardware store.
The only "free" energy is sunshine, which over the long haul makes fossil fuels if we don't kill off all the plant and animal life first.
cjdelphi
Oct 26, 2011
1,166
http://www.futurity.org/plug-in-to-a-low-voltage-tree/
people are using plants to produce voltage (side effect from photosynthesis) place plants in row create a battery ... i'd trickle charge batteries with something like a joule thief but more efficient .. (about as free as you get)
davenn
14,484
That's a real stretch, not really a valid argument ....
considering home installations are on roofs of homes others are out in areas where plant don't grow too well anyway ... deserts etc
Gryd3
Jun 25, 2014
4,098
Yeah. It's a stretch.. but you helped make the point that they are usually installed in locations where blocking the sunlight don't matter ;)
I think it's as close to 'free' as you can get, but you still exchange surface area of sunlight for electricity. Lucky for us, there is plenty of surface area on the planet.
Colin Mitchell
Aug 31, 2014
1,416
I have a source of one million tons of brown coal that costs me nothing.
Now I can produce FREE ENERGY too.
davenn
14,484
thread closed
and almost worthy of total deletion
Status
