USB external DVD/CD Drive in Linux OS.
ADRT
Nov 25, 2014
192
Found these two files in /root/
# ~/.bashrc: executed by bash(1) for non-login shells.
export PS1='\h:\w\$ '
umask 022
# You may uncomment the following lines if you want `ls' to be colorized:
# export LS_OPTIONS='--color=auto'
# eval "`dircolors`"
# alias ls='ls $LS_OPTIONS'
# alias ll='ls $LS_OPTIONS -l'
# alias l='ls $LS_OPTIONS -lA'
# Some more alias to avoid making mistakes:
# alias rm='rm -i'
# alias cp='cp -i'
# alias mv='mv -i'
and
# ~/.profile: executed by Bourne-compatible login shells.
if [ -f ~/.bashrc ]; then
. ~/.bashrc
fi
mesg n
Mean anything to you?
Gryd3
Jun 25, 2014
4,098
umask 022
# alias rm='rm -i'
# alias cp='cp -i'
# alias mv='mv -i'
and
. ~/.bashrc
fi
mesg n
You certainly are green to this Linux thing eh? (I'm Canadian... really :p)
Anyway, the majority of the file system cannot be altered unless you have credentials to sign on as 'root' or if the current user has the rights to elevate to root access. You've made some quick progress, but let's cover some more tricks for you.
If you are familiar with cmd.exe in windows, you should understand what 'bash' and 'sh' are. They are the 'shell' you use when you use the terminal in Linux, and they are responsible for spitting out text and running the commands you pass it.
Now.. as far as permissions are concerned, if the account you are logged in as has permissions to do so, you can do one of the following:
'sudo <command>'
'sudo bash'
'su'
sudo (Superuser Do, will run any command as 'root' which is the highest 'administrator' account possible in linux)
Using sudo before any command that requires it is a good practice, but you can take a shortcut and start a new 'bash' session AS the root user. You can then run anything you want.
su (Switch User, allows you to switch to root, but may require a password you do not have... this is why I suggest sudo first... as it will ask for the regular account password)
ADRT
Nov 25, 2014
192
lol. I am very green to programming all around. Learning as I go. So I changed to superuser, but still lsusb does not work. Is there another way for me to see where the drive address is?
Oh, and I live about 15 minutes from the Canadian border in Maine. Fact is the company I work for is based out of New Brunswick so I get it. :D
ADRT
Nov 25, 2014
192
So that put's me in /home/usr. Thats still not the root directory is it? No dev file in home/usr
Gryd3
Jun 25, 2014
4,098
Awesome. Considering lsusb was 'not found' you will not get it to work unless you download and install the binary or build it from source code. This is usually the case with 'custom' linux distrobutions... some tools will be missing.
Now that you are a superuser, some things will change.
First and foremost the prompt will usually change.
gryd3@Hubble:~$ sudo bash
root@Hubble:~#
Notice the $ sign compared to the # sign. # is usually a 'root' prompt.
Additionally, notice the tilde? ( ~ )
The ~ is a shortcut for your home directory. Which WAS /home/usr/ but now that you are root, it's somewhere else. (perhaps /root/ )
Regardless, the directory you are in now makes little difference, you now have permissions to edit the fstab and run the mount / umount commands as well as create / remove almost ANY file on the system.
ADRT
Nov 25, 2014
192
Ok, so I can edit fstab now. Here is what it looks like.
# /etc/fstab: static file system information.
#<file sys> <mount point> <type> <options> <dump> <pass>
/dev/sda2 / ext3 rw,errors=remount-ro 0 1
/dev/sda5 none swap sw 0 0
none /proc proc rw,nosuid,noexec 0 0
/dev/sda3 /alternate ext3 ro,errors=remount-ro 0 2
/dev/sda1 /boot ext3 rw,errors=remount-ro 0 2
/swap/swapfile none swap sw,pri=0 0 0
This is what I added. Tried sda0 as well.
/dev/sda1 /mount/sda1 vfat defaults 0 0
Kinda hard to do if I don't know what the path is right?
Gryd3
Jun 25, 2014
4,098
Notice that most of those items are in /dev/ ?
sda refers to harddrive 1
sdb refers to harddrive 2
sda1 refers to partition 1 on harddrive 1
sda2 refers to partition 2 on harddrive 1
sda3 refers to partition 3 on harddrive 1
So look for /dev/sr* or /dev/sdb . It's debian based, so you can always ask.
Additionally, you can 'tail -f /var/log/dmesg' and watch what happens when you plug in the usb device
ADRT
Nov 25, 2014
192
Ok. I'll try that tomorrow. Thanks for all the help and patience Gryd. I really appreciate it.
ADRT
Nov 25, 2014
192
So after much screwing around I've got it mounted. Yeah! Only problem is that I created a directory to do it so pressing the "Update Sytem" Icon still doesn't read from the disk. I'm assuming that it's because of the directory I created? Needs to be in a different directory?
mkdir /mnt/sr1
fstab edit
/dev/sr1 /mnt/sr1 udf,iso9660 usr,noauto,exec,utf8 0 0
ADRT
Nov 25, 2014
192
Ok, so there 's a symbolic link in /home/user/ called "CDROM". When you insert a disk into the SATA CD drive it turns into a directory and has all the stuff from the CD in it. How can I link my external drive to this symbolic link?
Gryd3
Jun 25, 2014
4,098
'ls -al' should show EVERY file in a directory, as well as where the symbolic link actually points to.
For example :
lrwxrwxrwx 1 root root 15 Jun 26 20:26 brian -> /home/brian/www
If the link you are talking about is /home/usr/CDROM you can simply rename it, and make a new symlink.
mv /home/usr/CDROM /home/usr/CDROM_
ln -s /mnt/sr1 /home/usr/CDROM
That should do it for you.. as now anything accessing the original CDROM from the /home/usr/CDROM path will use your symlink which is pointed to /mnt/sr1
This will only work if the update app uses the /home/usr/CDROM path though...
Is the update icon a script or an application?
ADRT
Nov 25, 2014
192
It's a script. I can find it under /user/icewam/toolbar/
PROGG Update System Update /user/local/bin/ UpdateSystem
Or something to that effect.
Gryd3
Jun 25, 2014
4,098
OK, because the update is a binary file, you can't tell exactly where it goes to access the CDROM, so you may need to make more than one symlink, but the process is the same once you find other access locations.
ADRT
Nov 25, 2014
192
Well that's the thing. User /local/ doesn't have anything in it but a file called share. On the cd there is two directories and a text file. One directory holds the update. The other directory is /user/local/bin/UpdateSystem
Somehow this is all done through the files on the cd.
ADRT
Nov 25, 2014
192
So the bin file on the cd runs the update which is a compressed file. Also located on the cd.
ADRT
Nov 25, 2014
192
The whole system is set up funny. Like /usr/media/ only contains a directory called "mirror". Nothing else.
ADRT
Nov 25, 2014
192
Actually, come to think of it, the directory on the cd where the update is stored is called "media" I believe.
Gryd3
Jun 25, 2014
4,098
well.. I think at this point, we will either progress at a snails pace.. or not at all.
You have all the details right in front of you, and other than playing with mounting points and symlinks I'm at a loss as to what to do next without actually being able to see the system myself.
It may be time to find some form of live chat focused on debian to get you rolling quicker.
ADRT
Nov 25, 2014
192
Just wanted to reiterate on this as well. After executing
All I got was info on the hard drive. After some meandering today through the system I tried Just
dmesg
Got all kinds of stuff then! Lol. But this was instrumental and finding that I was not connected to /sr0/ as I originally thought but actually at /sr1/. This was a huge help in figuring this all out.
ADRT
Nov 25, 2014
192
I have a few things I want to try tomorrow. I'm right there, I just know it! Thanks for all the help. I'll keep you informed as to my progress.
